I only want a certain line to ring without it ringing to all the phones in the whole office
SOURCE: Our office has 13 phones
You will have to go into system programming, under sets, line appearances. You will need to set the lines on the phones to appear and ring, not just appear.
SOURCE: Norstar m7310 I would like to set more phones to ring
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
if the programming doesn't look like 1 described call me @1.410.984.4840
SOURCE: only certain lines ring on certain phones
Programming is done on M7310, M7324 and T7316 sets.
The display should say line 001: appear& ring
press next key (lower right arrow)til you see the line port number you wish to program (004)
The display should say line 0xx: appear only
press the Chng key till it says appear & ring
Testimonial: "thank you so much!! thats exactly it!!"
SOURCE: lines ring to intercom
It sounds like although they're labeled as line buttons actually they're programmed as station buttons.
If you press feature *0 and one of the buttons it will tell you what the button is programmed as.
Also did you try pressing the intercom button then dialing 9? that might be the way the set was programmed.
SOURCE: Our office has a combination
Dial "F * 0" (Feature, star, zero), which is Button Inquiry, and press
an intercom button to see the extension number of the telephone.
If Set Relocation is set to "Yes", then the extension number &
mailbox will follow the phone when it is moved. Move only two
phones at a time, and wait until they completely "boot-up" before
moving additional phones.
Hope this helps.
