Suddenly won't microwave...All functions (light, clock, microwave set functions, etc.) work fine...Nothing happens when you press "Start"....Please help...Thanks...
It is blinking where the time is supposed to show up like when the power goes off. I hit the clear/stop button but nothing happens. It won't do anything.It is blinking where the time is supposed to show up like when the power goes off. I hit the clear/stop button but nothing happens. It won't do anything.
SAME PROBLEM, MICROWAVE GOES ON BY ITSELF WHEN I TURN ON THE ELECTRICAL BREAKER ON THE PANEL. IT STARTS COOKING AT 3 MINUTES AND I CANT STOP IT OR DO ANYTHING (NONE OF THE BUTTONS WILL WORK) UNLESS I OPEN THE DOOR OR TURN OFF THE BREAKER.SAME PROBLEM, MICROWAVE GOES ON BY ITSELF WHEN I TURN ON THE ELECTRICAL BREAKER ON THE PANEL. IT STARTS COOKING AT 3 MINUTES AND I CANT STOP IT OR DO ANYTHING (NONE OF THE BUTTONS WILL WORK) UNLESS I OPEN THE DOOR OR TURN OFF THE BREAKER.
AnonymousMar 23, 2014
Everything works on my microwave (buttons) however; when you press "Start" absolutely nothing happensEverything works on my microwave (buttons) however; when you press "Start" absolutely nothing happens
Nothing happens when I press startNothing happens when I press start
AnonymousMar 26, 2014
My microwave quit working, light is on in microwave but not startingMy microwave quit working, light is on in microwave but not starting
AnonymousMar 28, 2014
When you push the defrost button comes up on screen but when you push start nothing happensWhen you push the defrost button comes up on screen but when you push start nothing happens
You can't post conmments that contain an email address.
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
It seems like you're experiencing an issue with your Panasonic microwave oven NNT551. If the clock button is not responding and you only see two dots when pressing the stop button, there might be a few things you can try to troubleshoot the problem:
Power Cycle the Microwave:
Unplug the microwave from the power outlet.
Wait for about 30 seconds.
Plug it back in and try setting the clock again.
Check for Child Lock:
Some microwaves have a child lock feature that can prevent certain buttons from functioning. Check your manual to see if your model has this feature and how to disable it.
Reset to Default Settings:
If there is an option in the manual or settings to reset the microwave to its default settings, try doing that.
Inspect for Physical Damage:
Ensure there is no physical damage to the control panel or any other part of the microwave that may be affecting its functionality.
This could happen because of bad door switch or a loose door mount .This is the main reason that microwaves not heat even if the other functions work fine .
Warning : A microwave is capable to give you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
I had this problem too: it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes, the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
PLease open the housing of turn table motor at bottom of the oven and check for the AC input voltages on motor terminals as specified on sticker on motor.
for no heating please check fuse between high voltage transformer and high voltage capacitor.
Also check high voltage Diode and Magnetron.Please please don't try to measure voltage on terminals of magnetron.
