No jammed paper can be found
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
SOURCE: Misfeed detected. I have opened everything I know
there is a piece of paper in the area between the tray 1 and the door. sometimes you can use cardstock to push the paper out. try it
