There is a place to put the bleach but I can't figure out where to put the fabric softner. The cap comes off on top of the aggatator, but if you put the stuff in there it runs out into the wash water. HELP.
It goes into the top of the agitator on that machine. It should look like this.
SOURCE: ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
SOURCE: Top Load Roper Washer does not agitate during wash/rinse cycle
You may need to replace agitator dogs located inside the agitator or the drive coupler located above the motor. It dependis on which model you have.
SOURCE: Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
SOURCE: I have a Roper top load washing machine and the
the washer needs to have the lid closed to go into spin cycle the lid switch is broken just replace it and that will fix it
SOURCE: My Roper washer model number
Your main barring that controls the spinning is going out. Try and see if can spray lubricant to oil/ grease to see if that helps.
Once the cycle begins, you can't lift the lid.
