Cell Phones Logo
Sophie Vlahos Posted on Oct 19, 2012
My htc incredible s won't charge, I've tried
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Oct 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
1814
Points
23
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
2 Related Answers
helpdesk101
  • 128 Answers
  • Posted on Sep 01, 2011
SOURCE: HTC Hero won't charge. I
U can call your service provider they might be able to help ifthey cant assist you contact the phone manufacture either way you will get ananswer to your problem.
Scott Mackenzie
  • 8 Answers
  • Posted on May 16, 2012
SOURCE: my nokia E5 won't charge, I've tried another charger but still nothing
can you see the pin in the charger socket? these can get bent, other wise looks like your charge socket has come free, from the board
1helpful
Incredible 2 phone won't turn on
your phone is not supported 32gb memory card that's why your phone is totally hang so if u want to fix it you have to update your software and go to a service station
Htc droid incredible 2 won't charge
FOr changing the charging port you have to take it to an authorized service center. it could be a software issue also.
4helpful
3answers
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
1helpful
2answers
My htc incredible s wont charge the port is broken how can i fix
I you're out of warranty, you can totally do it yourself. you can get the part at HTC Incredible Repair and there is a guide that shows you how to put in the part at HTC Incredible Repair Guide.
HTC Hero won't charge. I bought a new battery...still won't charge. I've tried a wall charger and a car charger and neither of them work.
I previously had a problem with my Netbook power jack on the side of the computer, but it seems to be fixed now. When I plug the adapter into the computer, the orange light comes on showing that it's...
I guess it depends on why your power jack was dameged at first.
If the old power jack was replaced after any electric accidents, this current problem can be caused by your damaged motherboard.
(After shock, the motherboard can still perform ok for a while. I've seen it.)
Or sometimes, rarely the battery can cause it. I don't know why but, that's what I've heard from laptop manufactuers.
To find out, please, take out the battery and plug in AC power adapter and try it again.
I hope it helps you.
Just got a HTC incredible s and i plugged it in to charge and the phone shows no signs of charging. help!!!!!
I would take the USB cord and plug it into your computer and charge it that way. There has been some trouble with the wall charges coming with phone not working. If it still won't charge, its time to take it back to were you got it. Good Luck!
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
