Question about Boating
Mariner 8hp 2 stroke what year is it serial number 9516681 Hi ive recently purchased this engine and i am having trouble finding the year of the model.. engine idles fine and revs up with no problems but as soon as i select a gear it wont go over 1500 rpm under load. seems like its starving of fuel.. tank vent is open and carb recently been cleaned.... please help
  • Boating Master
  • 3,577 Answers
Hey Steven,
get one of these manuals, you will be glad you did,, it will serve you well for as long as you own your Mariner! The guys at MarineEngine will be glad to help you too!!
Mariner Outboard Service Repair Manuals by Seloc 1977 2004
Outboard Motors Boat Parts Marine Engines Inboard Boat Motor
Posted on Sep 19, 2017
3 Suggested Answers
SOURCE:
  • 77 Answers
SOURCE: Mariner 25 hp 2 stroke hard to start then quits and won't restart
It sounds like the float is sticking in the carb. Since the carb is higher than the fuel tank it pulls the fuel in by vaccum of the engine. when running at high rpms, it can burn the fuel thats flowing into the carb, when you idle down, the bowl of the carb is filling up with fuel faster than the engine can burn it and causing it to flood. Then when it shuts off at idle it does not want to start back up because it is flooded. To make a long stary short, pull the carb and give it a good cleaning and your problems should be solved.
Posted on Aug 02, 2009
  • 86 Answers
SOURCE: 2003 115 mercury efi losing power
I am a Mercury certified technician. What you need to do is take it to a Mercury dealer and have them hook it up to the computer. It sounds like the engine could be in Guardian mode or possibly a high RPM misfire. It is not something that is common and the computer program that Mercury has for those is able to test misfires and all sorts of cool stuff. It can also tell you if the engine was broke in properly, how many actual running hours are on it and even at what RPM each hour was ran. It will be able to bring up all faults that it has had in the past and any faults that are current. I know that you are probably looking for a quick, easy fix but for this problem I dont think that there is any way around taking the engine in. For what it is worth, if they charge you for more than 2 hours to run it on the computer then take it somewhere else. I can fully test the engine with the computer in about an hour. The only reason that it would take any longer is if they had to put it in the water to duplicate the problem but most shops will have a test tank that is capable of running your engine under a load at full throttle. Sorry for the bad news but I cant think of any other way and throwing new parts at it is just going to get expensive quick.
Posted on Aug 11, 2009
Year of 8hp mariner serial number OC179412. Location of water inlet.
HELLO: I think i might have the information you need,bellow the mounting bracket,next down the mid section to the lower unit on the same side as the mounting bracket,you have the antie ventelating plate,then comes the WATER INTAKE right opposit the prop. im sorry but i was unable to find a diagram for your needs ,im hoping this will help .GOOD LUCK M.M.
Apr 23, 2018 | Boating
I have a 1981-1985 60hp Mariner 2 stroke motor. Need owner's manual and how can I find the serial number and the year of the motoR? Which website can i search?
http://www.boats.net/parts/search/Merc2/Mariner/parts.html, searial is on the flat part near the out put shaft from the crank. usually covered in grease and dirt.
Feb 04, 2018 | Boating
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Sep 25, 2016 | Mercury Mariner Starter, Outboard, 35-40...
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Feb 27, 2015 | Mercury Marine 4hp & 6hp Stroke Outboards...
Find the manufacture year mercury verado motor
According to i-Boats, "Nothing in the Mercury Mariner Outboard engine model numbers or serial numbers provides year information directly.
The first serial number sold in a year becomes the beginning serial number. Serial numbers between that year's beginning serial number and the next fall into the same year. Search for your engine horsepower on the Mercury Mariner serial number year chart located here to find the beginning serial number for the range that includes your engine." Your other option is to take the serial number to an authorized Merc marine eager and they can look it up for you.
Sep 27, 2014 | Boating
75 horse power ercurywhat year of manufacture serial number 06255293
There is no data included in the serial number that gives info of what year the engine was made. You can, however look up the number here, and that will tell you the year of manufactor.
http://www.iboats.com/basics/serial_number_year.html#mercury
Aug 15, 2014 | Clymer Mercury/mariner 75-275 Hp...
Mercury outboard s/n 9445826, what year was this motor built ?
call mercury outboard they can tell you the answer to your question
Aug 29, 2013 | Raymarine St6002 Smartpilot Hydraulic...
Boating Logo
200 people viewed this question
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
