Frigidaire GLEB27S7A Electric Single Oven Logo
Joyce Young Posted on Oct 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Electrolux Frigidaire Self Clearning Convection Oven. I was cooking yesterday when it went off and I cannot get any heat now. The oven still lights up when I turn it on. The fan still wor
Both Elements went at once and I cannot get any heat in my oven. How can I solve this problem.
  • Official Brand Answer 4,342 Answers
  • Posted on Oct 24, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467856
Points
5907
Hello - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
2 Related Answers
Anonymous
  • 291 Answers
  • Posted on Dec 11, 2009
SOURCE: Frigidaire Oven making vibration noise when
This usually is caused by a bad convection fan motor. This is something that you should have a technician replace, but ask for a price quote first. Fairly expensive to fix and usually very complicated to get at. Good Luck, Appliance Specialists
Anonymous
  • 43501 Answers
  • Posted on Dec 26, 2010
SOURCE: I have a Frigidaire electric oven and flat cooktop
With the symptoms that you are describing here ...the problem is in the control board... you still have power, but nothing is being told to turn on...the control board controls all of those functions...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
No heat on convection or self clean
If you have been using the self clean feature, you have probably burned out or damaged the connections to the fan and the convection fan element or thermistor. NEVER EVER use the self clean feature.
https://www.partselect.ca/Models/CGEB27S7CS2/Sections/BODY/?ModelID=1073773&ModelNum=CGEB27S7CS2&mfgModelNum=&ManufactureID=4&Selected=OTRVH5GS&Position=1&mfg=Frigidaire&Type=Wall%20Oven&Mark=1
4 Reasons to Stop Using Self-Cleaning Oven Feature ...
https://fixappliances.ca > 4-reasons-stop-using-self-clea...
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or 500 C°) to ...
‎How Self Cleaning Ovens Work · ‎Major Parts Damage · ‎Family Safety
Why You should Never Run A Self Clean Oven Cycle & A ...
https://www.generalappliancesvc.com > why-you-shoul...
Jan 29, 2020 - With an inside temperature exceeding 500° C, and a flash point (the temperature at which items can self-combust without an ignition source) .....
How to stop convection fan from hitting heating element in Electrolux oven?
I would replace the fan assembly as it sounds like the blades have moved on the shaft unless there is damage to the element fixings caused by ramming a cooking utensil into the oven that is too big of course.
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
I have a frigidaire Electrolux self cleaning convection oven. I put it on self clean and it went fo over ten hours. now the door is locked and I cant open it. I tried to self clean and it wont start. The...
These ovens have notoriously bad control panel electronics. There is one control board for the oven that can be replaced or sent out for repair, $100 to $300.
1helpful
Frigidaire Oven making vibration noise when Pre-Heating or Convection cooking. Only notice when convection fan is running.
Uneven rising & baking in convection oven
I repair commercial cooking equipment for a living. When a customer complains about uneven cooking the #1 thing that these manufacturers ask is..... are they turning (180*) the baking sheets half way thru the cook cycle. #2 are they staggering the pans front to back & side to side. It's kind of a pain but, works for the commercial ones.
Frigidaire oven will not heat up
Not popping sound you heard was the element popping take care of it out did you take your fingers and go round the outside of the element you'll find a whole the place that element you get your heat back
My oven will not heat up at all.
make sure your cooking timer is on manual....
1helpful
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 • Ovens
Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
