Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Blade is hitting the bowl and the screw will not turn anymore
I tried to adjust the screw so the blade would not hit the bowl, but it will not turn to the left any further. Does ant one know what is wrong?
  • 135 Answers
Turn the screw to the right. It will only turn a quarter turn. If that doesn't help try to file a bit of metal off the bottom of the beater. If you find this solution helpful, please rate it. ricardok45
Posted on Jan 05, 2009
SOURCE:
Why my kitchenaid mixer beater hit the bowl?
The screw which can be seen at the pivot when you tilt the head back needs adjusting. Turn it counterclockwise a bit at a time until the beater no longer hits the bowl.
May 25, 2014 | KitchenAid 32685 Mixer
Beater hits bowl beater height adjustment screw does not fix problem
Is this a new beater that you just bought? Or is it the same beater you have had? When you adjust the screw, which way are you turning the screw, how much is it hitting the bowl?
If the beater is too close to the bowl the adjustment screw should be turned in. If the threads on the screw are loose the screw needs to be replaced.
Page 17 and 21 both show how to adjust the head of the mixer so the beater his the bowl correctly. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Please let me know if you have any questions.
Thank you,
Colleen
Customer Service
MendingShed.com
customerservice@mendingshed.com
800-339-9297
Apr 14, 2013 | KitchenAid Artisan Series Tilt-Head Stand...
Vibrates and beater hits bottom of bowl
Try adjusting the height of the head by turning screw #36 counterclockwise a turn or so. This will raise the mixing head so the beaters no longer hit the bottom of the bowl. Refer to parts list:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
If the pivot pin #18 is not centered and secured then center the pin and turn the mixer on its side to tighten screw #31 from underneath the mixer to secure the pivot pin.
Apr 17, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Mixer blade is chipping
If it is a tilt head mixer then adjust the screw which can be seen by tipping the head back and looking into the pivot point. Turn the screw CCW to raise the head and prevent the paddle from hitting the bottom of the bowl.
If it is a lift bowl mixer there is an adjusting screw on the frame of the stand behind the bowl holder mechanism. It rurns a cam which adjusts the height of the mixer.
See pg. 13 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707917.pdf
clockwise to lower the head and counterclockwise to raise the head for more clearance for the beaters.
I need to raise the head of the mixer. The wire whip is hitting hard the button
Hi LEDAVETTORI, you don’t provide the model number or say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, which would helpful, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and select a file listed under Owners Manuals and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater. •Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 18, 2009 | Food Mixers
KitchenAid model KB26G1XGN. The planetary gear appears to be falling out. The mixer blades were hitting the bowl before I had the bowl in the locked position. I got the top of the gear box off but can't...
Hi TJEWKES67. Before you tear into the ‘guts’ of your mixer any further, I’d like you to make a simple check the vertical play of the planetary. Locate where the planetary comes out of your mixer’s head, and place your left index finger on the edge of the planetary (rest your nail edge of the mixer head). With your right hand, push the planetary straight up (like you were trying to push it through the top of your mixer) until it stops, then let go. How much vertical movement did your index finger feel as you did this? Your planetary shouldn’t rise vertically more than a 1/16 of an inch, or less. If that’s the case, relax, your planetary is not coming out of your mixer, but just normal play within the transmission, and perfectly OK.
Before linking the beater to bowl clearance with the planetary gear ‘falling’, it would be much easier to first check the adjustment screw on the back of the pedestal to ensure that is properly adjusted. You don’t say how hold your mixer is, but I assume it is out of warranty.
Do you still have your Instructions & Recipe Manual for your mixer? If not, you can easily download a PDF version of it from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case, use KB26G1XN, and select the file that appear under Owners Manuals: KB26G1XGR5.pdf (2974.69 KB) and save it to your PC. Turn to Page 11 and you will find the instructions for adjusting the Beater to Bowl Clearance, which I have extracted for you below:
Beater to Bowl Clearance:
Your Stand Mixer is adjusted at the factory so the flat beater just clears the bottom of the bowl. If, for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, you can correct the clearance easily.
1. Unplug Stand Mixer.
2. Place bowl lift handle in down position.
3. Attach flat beater.
4. Adjust so flat beater just clears bottom surface of bowl when in lifted position by turning screw (A) clockwise to raise the bowl and counterclockwise to lower the bowl. Just a slight turn is all that is required: the screw will not rotate more than 14 turn (90 degrees) in either direction. (The full range of adjustment is 12 turn, or 180 degrees.)
5. Place bowl lift handle in up position to check clearance.
6. Repeat steps 4 and 5 if necessary.
NOTE: When properly adjusted, the flat beater will not strike on the bottom or side of the bowl. If the flat beater or the wire whip is so close that it strikes the bottom of the bowl, coating may wear off the beater or wires on whip may wear.
See second comment...
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 12, 2009 | Food Mixers
The bowl fits too close to the mixing blade and has scraped some of the surface from the blade. I can not find the book
VLCMM: You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of yourOwners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home). Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals: KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC. You’llneed to have Adobe Reader to be able to open it. Turn to Page 11 and you will find theinstructions for adjusting the mixer head height. I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Make adjustment with flat beater, so it just clears surface ofbowl.
If you over adjust the screw, the bowl lock lever may not lockinto place.
Bowl-Lift models
• Unplug mixer.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flatbeater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface ofbowl.
If this solution has helped you, please rate it, thanks!. hslincoln
Nov 25, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
The motor is loose a little and needs adjusting up, because it hits the bowl when in motion.
I think from your description that the the head connecting to the base shaft needs tightening. Put the mixer on it's side UNPLUGGED. Look up inside the base and you'll see a small set screw.
With a flat blade screw driver tighten that screw and it should stop moving. If it doesn't you probably need another shaft because it's worn. If after tightening it stops rocking but it still hits the bowl there's another screw at the front, on top of the neck under the head. Turn this until it clears the bowl. Good luck!
May 01, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
186 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
