Washing Machines Logo
Anonymous Posted on Jan 01, 2009
Bearings replace
Paul P
Level 2:
Filmmaker:
Uploaded 5 video answers.
Scholar:
  • Fisher and P... Expert 80 Answers
  • Posted on Feb 25, 2019
Paul P
Level 2:
Filmmaker:
Scholar:
Answers
80
Questions
0
Helped
61394
Points
218
Anonymous
Level 2:
  • Expert 144 Answers
  • Posted on Mar 27, 2009
Anonymous
Expert
Level 2:
Answers
144
Questions
0
Helped
82945
Points
350
I can talk you througt this in live chat, but you'd need to get a F&P Bearing replacement toolkit and seals and bearings and a new agitator shaft. cheers
Is it possible to remove and replace front wheel bearings with out a press
In order to remove the front wheel bearings without press hub off the bearing and then the bearing out of the knuckle. To do the first step need a a Support Bridge.It is a special tool. Make bridge and use a general bearing pulled kit to replace bearings. use a "Front Wheel Drive Bearing Removal Adapters Puller Pulley Tool Set Kit" .To replace the bearing, remove front CV shaft taking care not to move the CV shaft too far out .
How to replace bearing on driveshaft of a 1992 isuzu rodeo
to replace the bearing you must seperate the axle from the rear differential. Then remove the rear section of the driveshaft and then the carrier bearing assembly. Replace the carrier bearing assembly then replace the driveshaft.
1helpful
The bearings on my Whirlpool Cabrio WTW6400SW3 make a racket on the spin cycle. The Whirlpool parts diagrams show that to replace the bearings, the entire drum is replaced. I can see one of the bearings...
Yes you can just replace the bearings but be careful. they say to replace the entire drum as the materials they are made out of is not very strong and you can distort or damage the drum when removing the bearings.
1helpful
I think the bearing on front of motor is going . Can it be replaced or does whole motor need replacing . Unit is cooling very well but making some noise and shaft of motor getting hot. Unit is Coleman...
the bearings are replaceable on some motors.. its a bit of work and you might first check the cost of a replacement motor .. it might be low enough to offset the amount of labor required to replace the bearing .. around here we have a hardware store that has a stock of most common replacement bearings ... some motors have welded bearing cages or bent metal captures .. those are harder to deal with. a way to make at least temporary repairs of such bearings involves punching the bearing to expand it , then re-drilling the bore to the correct size .. you might be able to force grease in the bearing for now to give you a little more time .. as it is it will eventually damage the motor shaft such that bearing replacement will not be reasonable ..
2helpful
Bearings Replacement
Bearings can be replaced without replacing the drum.
this is a major job,So,I would not recommend trying this yourself
Please rate this fixya
1helpful
Pinion Bearing
the only way to replace pinion bearings is to remove the differential. you shouldnt have to remove the bearing to replace the seal
2answers
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
