Amazon com Charm sonic Wireless CSR4 0 Portable Bluetooth Receiver...
Software problem or change the settings in Bluetooth menu something like always remember or always available sort of. or see your phone memory.
SOURCE: I receive the following message when I try to take
i was having the same problem and i went to settings then to sd card and clicked on Unmount SD card and i took out the sd card, then placed it back into my phone and now i can take pictures and video :]
SOURCE: receive files via Bluetooth
I think that files received via bluetooth are saved in to the phones memory unless you have an option to choose location. Otherwise after receiving filr manually move from device to memocard.
SOURCE: My htc hero pairs but then says paired but not
The Hero has a rather crippled Bluetooth which is one of the reasons I'm sending mine back.
For security, when you set the phone to be discoverable it only stays that way for 90 seconds. This cannot be altered unless someone works out how to bypass it with an app but I understand from HTC that this feature is built in at the firmware level.
Look down at the devices list in the Bluetooth menu and you'll see what's paired with the phone; press menu and you'll have the option to connect.
Bluetooth on this phone cannot be used for file transfers of any kind. It's only there to enable connection of devices like headsets and external keyboards and that's about it. You can't even take a photo and Bluetooth it to another phone. There is no way around this at present.
Not connected with your question, but have you discovered the annoyingly expensive and non-alterable trick which it does when you want to send/forward long SMS messages yet?
Testimonial: "thank you much appreciated and no i haven't herd of this annoyingly expencive tirck! could you enlighten me thanks again for your help!! "
SOURCE: Meteor settings required for HTC hero please.
I'm a HTC Hero user on Meteor BillPay. Had the same problem and got the following solution from Meteor support which worked for me. On the phone, navigate to :
- Settings
- Wireless Controls
- Mobile Network Settings
- Access Point Names
- Meteor Data
- APN Type
Change the value here to the word "default".
Restart the phone and bob's your uncle. I did this and it worked a treat.
SOURCE: i am using htc wildfire i have to use my mobile
Prashant,
You do not have to copy this file to your laptop. You have to copy and run this file so that the drivers for the cell phone get installed on the laptop. Then only would you be able to use the phone as a modem.
To get this file please follow the guidelines in the link below
Search for Drivers Online
Installing Devices on PCs and Laptops
