SOURCE: maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
SOURCE: Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
SOURCE: Maytag Dependable Care M# LAT9416AAE will not
It sounds as if the floating motor mount is no longer floating or the 2 springs inside of that floating / gliding mount are not working correctly. There are also 4 hard rubber clear washers that are part of the gliding mount. If any one of the 4 of those washers has broken the motor does not glide properly and will not tighten the belt properly for the spin cycle to work. Make sure the unit is unplugged reach underneath the left front corner and feel for a 2 V belt groved pulley. First push the pulley inward 45 deg from the corner and let it go.... If it is working properly it should automatically tension the belt. If is sticks in position the either the springs or washer have failed. This is not an expensive repair. IF you call for a repairman make sure he checks the condition of the tub drive belt. The motor has been placing undue wear on the drive belt due to it being loose.
