Hi..I have a roper rex3514rq1..the dryer blows warm air but not hot enough to dry clothes..Will I have to replace the element? If so, could you provide a repair guide and the part needed..thanks..John
Roper by Whirlpool/heavy duty/exlcap/3 cyc
Make sure u have seleced the high heat setting..The fact that it is heating more or less indicates that the element is o/k.
Check and clean any filter(s) that u can see,it is more likely to be a thermostat problem than anything else. and there are at least 2 of them, also check line voltage is correct.
Plz rate this solution.
thanks.
The ROPER support page is very unhelpful(see below) bought out by Whirlpool in Canada but the model numbers do not cross over.
Yes, I beleive you wil have to replace the eliment. Isolate and test it with an ohm meter to be sure. It should have a high resistance reading. Parts can be found many places on the internet or local appliance parts places.
http://www.roperappliances.com/support/
