Hi rick,
I see that there was a power outage, now your wireless will not turn ON as you mentioned.
Have you tried checking the Linksys Router settings if the Wireless radio is turned ON.
It is possible that when the power went out the Router was reset to default and may have turned OFF the Wireless Radio on the Router.
- Next open a web browser window on the connected computer and type http://192.168.1.1
into the address bar and press enter. A window will pop up prompting
you for a username and password to access the configuration page for
your router. Enter admin for both the username and password.
- You should see the Setup page.
Make sure that in the Wireless page that the Wireless SSID Broadcast is Enabled because if it is Disabled your wireless device will not detect the Router at all.
Also you try and reset the Router from behind, there should be a PINHOLE Button there that you can press and hold down for at least 30 seconds to reset the Router s settings to defaults.
If still the Wireless Light will not Turn ON then most probably the Power outage may have damaged the wireless radio on the Router.
I hope that this will help with your concern.
Have a nice day,
mvincentc
