Question about Krups KM7000 10 cup Grind and Brew coffee maker with conical burr
Krups KM7000 won't make a full pot.
Just bought a Krups KM7000 Grind & Brew coffee maker and it won't make a full pot. Even when we fill the reservoir right to the very top, the best we get is 8 cups. I'd appreciate any ideas you might have. It makes a great cup of coffee and I'd hate to have to replace it.
    New Friend:
My post on a different problem ( more common problem)
Sorry its not an answer YET.. Im working on solving it. ( I LOVE THIS COFFEEMAKER) despite the problems!
"I'm now experiencing what the original poster is experiencing, I've fixed the thermal fuse problem twice so far over the last two years. The thermal fuse allow the water flowing through the tube under the plate to heat witch forces it up to the brewing lid, if the fuses blow = no heat= no steam.. we are experiencing EXCESSIVE steam and verrrry slow brewing. Mine takes over an hour to brew half a pot and I have to fill the reservoir twice to get 2\3 of a pot.
It's all going to steam,, suggesting, to me, the temp is getting WAY TO HIGH.
Am I right? does anyone have any more info or clarification.. and what part might fix this.
how is the temp getting too high.. is there a temperature "SWITCH" somewhere?"
Posted on Nov 14, 2014
  • Jim Lee
    Jim Lee Sep 14, 2015
    Do you find a fix? Mine is doing the same thing. Not the fuses. Maybe the water check valve in the bottom of the tank?
    Problem Solver:
  • 4 Answers
I have one. there is a setting on how many cup you want 4,6,8,10, or 12 cups
Posted on Oct 18, 2012
  • 2 more comments
  • Monique Kmucha Oct 19, 2012
    Sorry, guess I should have said more. We have it set to 10 cups, which is the highest it will go, and still only get eights cups at best.
  • Tony Oct 20, 2012
    If you just bought it, I would call Krups and tell them whats going on. That machine is probable a defect. Sorry I couldn't help you any further
  • Monique Kmucha Oct 21, 2012
    You're right, we will definitely call and ask them for assistance. In the meantime, we've found a work around. We leave about a cup of water in the pot before the brew. Making the grind finer makes the coffee stronger so the extra water doesn't seem to hurt the taste. Still the best cup of coffee I've ever made at home! Thanks for your response!
  • Brad Oler
    Brad Oler Nov 14, 2014
    youre def having an isue that will be warranty, im having this problem too,, let me guess HUGE billowing clouds of steam right?:) . send it in if you have warranty!!
SOURCE:
Where can I get a thermal fuse harness for a Krups mk7000
If it is no longer available why not read the temperature rating on your dead fuse and replace the fuse only?
Aug 18, 2014 | Krups KM7000 10 cup Grind and Brew coffee...
This is the Krups Grind and Blue Coffee Maker purchased from Amazon 7/8/11. It is the second one I purchased. Krups factory service AND local service station phone lines are constantly busy. On this...
Sorry for the delay. I will need to look up some reference materials and drawings on this before I can aupply an acurate answer. Been one of those nights and I apoligize for the delay.
Sep 30, 2011 | Krups KM7000
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
I set up our new coffee maker and it didn't grind...ordered it online from Macy's but had no manual and didn't know what to do...put coffee grinds in the top and then set up the timer for this...
You need to swivel the brew basket cover until it locks for the coffee to grind. Then turn the machine on and the coffe will grind. , then turn the machine off, add water and press the auto on to use the auto timer.
Dec 13, 2009 | Krups KM7000
Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
Nov 20, 2009 | Krups Coffee Makers & Espresso Machines
Krups KM7000 grinds but won't brew, warming plate no heat. Is this repairable, (perhaps a fuse?) or is it junk. Bought the machine in March 2008
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Oct 30, 2009 | Krups KM7000
How do you grind the coffee beans
open the brew baSKET LEVER UNTIL IT LOCKS, THEN TURN THE MACHINE ON.
Jul 12, 2009 | Krups KM7000
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Krups KM7000 10 cup Grind and Brew coffee maker with conical burr Logo
319 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
