I am using an HDMI to DIV-D adapter then an HDMI cord to connect my computer to a 4 port selector which then connects to a projector. When I do this my system goes to a blue screen stating error which may be caused by a new hardware device. What do I need to do so that my system recognizes this new hardware? I am able to start my system in safe mode with networking.
SOURCE: Connecting HDMI cable to Dell Dimension 4600 PC
its not possible. but u can add in a PCI card that supports HDMI
SOURCE: when i boot up the xps 410 the screen goes to
there is a strong possibility that you have a video card failure.
SOURCE: I have a dell dimension 8400. The graphics card
You may have left out a couple of steps.
Now, you need to configure the new display,
by selecting "Control Panel" from the "Start" Menu. Then double-click
the "Display" icon and click the "Settings" tab.
The manual for your
HDMI TV will list the screen resolutions it supports, along with the
refresh rates. Configure the resolution in the "Settings" tab, and then
click the "Advanced" button to set the refresh rate.
If you are using
the HDMI TV as the second monitor, you will also have to configure how
it is used by Windows, according to the instructions pertaining to your
video card. Most cards offer a "Clone" or "Mirror" mode, where both
screens display the same content. Alternately, the "Extended Desktop"
mode can be used, in which each monitor will operate independently.
Now, again, reboot your PC to apply the changes.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
SOURCE: My Dell Dimension 4600 is now showing the nv4_disp
Is certainly worth trying another keyboard they dont cost much nowdays but with all those problems i would format the PC and fresh install windows making sure you get all the correct drivers from the Dell website. Hope it works
SOURCE: Have a Dell Dimension 4600C Desktop. It no longer
More than likely it is your ethernet card that is bad. It will be easier to buy an ethernet card and install. The procedure is not hard. You will need to open your computer and sit the card in one of the open slots toward the back of the computer.
1) Look at your laptop computer to see if
you have an HDMI cable port. This port is roughly half an inch wide and
provides both the HD audio and video signal. If you don't, you are going to use
a DVI port on the laptop. This is the same port you use to connect monitors to
your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the
Blu-ray player. If you have an HDMI port on your laptop, you can skip this
step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an
HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD
television. Power on your television, press the "Input" button and
select "HDMI." You can now see the contents from your Blu-ray player
on the TV.
Thanks for rating
Good luck
