Hotpoint Aquarius WMA42 Front Load Washer Logo
Posted on Oct 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint aquarius WF541 won't finish a cycle
It won't finish a cycle i need to put it to fast spin and the lights flash on mini load
Richard Roth
Level 3:
Top Expert:
  • Hotpoint Master 9,472 Answers
  • Posted on Oct 20, 2012
Richard Roth
Hotpoint Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626537
Points
28464
What is the model number? Look inside the door area.
5 Related Answers
Anonymous
  • 166 Answers
  • Posted on Sep 10, 2008
SOURCE: Hotpoint aquarius wf320
Hi charlie99 Peace,
ngafm At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT.
If not only a trained laundry tech can make the electronic diagnoses.
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Anonymous
  • Posted on Oct 30, 2008
SOURCE: HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
you are all a bunch of cocks
Anonymous
  • 53 Answers
  • Posted on Oct 26, 2009
SOURCE: hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 28, 2009
SOURCE: aquarius hotpoint wf541 wont pump the water out at
You need to clean the filter.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well
Hope this helps with your problem
Anonymous
  • Posted on Dec 30, 2010
SOURCE: Hi our hotpoint wf541 starts its cycle as normal
hi i had the same problem.
its either your filter is blocked or your pump is not working.
after switching the power off, remove the front bottom panel of the machine and unscrew the filter cap on the right behind that panel. check it's intact and clean iside, if not clean it out or replace it and that should fix it. be careful screwing the filter cap back in and make sure its on tight.
to check your pump is working you can pull out the machine and check that water is coming out of the hose by putting it on the pump out / drain cycle after pouring in some water for it to pump out.
4helpful
2answers
Hi our hotpoint wf541 starts its cycle as normal but doesnt spin and the mini load and reduce crease buttons flash as well as the on/off button, any ideas of how i can fix this thanks.
2helpful
Hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
8helpful
3answers
Aquarius hotpoint wf541 wont pump the water out at the end of the cycle
3helpful
2answers
Hotpoint wf540 stopping on a rinse and spin and
1helpful
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Same problem
Power it off at the mains for 60 mins and then rety. If it still does the same then call in a repair man as it is most likely thatthe main controller board is faulty and needs replacing.
15helpful
4answers
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
7helpful
2answers
1helpful
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
