Washing Machines Logo
Ron Tait Posted on Oct 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does Frigidaire affinity dryer code E61 mean
Richard Roth
Level 3:
Top Expert:
  • Frigidaire Master 9,472 Answers
  • Posted on Oct 20, 2012
Richard Roth
Frigidaire Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628352
Points
28464
E61 is a line voltage problem, most of the time it means you have the neutral and the L2 wire either reversed or in the wrong position. Verify that the voltage is correct at the plug then at the machine and that you have 240 volts at the terminal block on the back of your dryer.
  • Romer Moran
    Romer Moran Oct 10, 2016
    thanks a lot, working now
5 Related Answers
Anonymous
  • 57 Answers
  • Posted on Mar 04, 2009
SOURCE: frigidaire affinity dryer makes buzzing noise when
your motor is out you need to replace it
Anonymous
  • 240 Answers
  • Posted on May 04, 2008
SOURCE: ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
Anonymous
  • Posted on Sep 26, 2009
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Anonymous
  • 39 Answers
  • Posted on Apr 22, 2010
SOURCE: What does error code E59 means on a Frigidaire
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
Anonymous
  • 643 Answers
  • Posted on Jun 07, 2011
SOURCE: Frigidaire Affinity ATF7000ES Front Load
DR code means that either the door is not closed or the door sensor is bad
Frigidaire affinity is giving 3 codes E63 first E61 second and E62 the third help?
Hello good day,
The E means error !
This means that you need to follow the operation seating to be able to operate it again or you we have to reset the dryer again.
Thanks,
Good luck.
Affinity Model FASE7074LRO. Why is it displaying E61 code?
E61 is a stuck relay on the main control board. This is the board right behind the control panel where all the buttons are. You'll need to order and replace this board.
Frigidaire affinity dryer error code e61 after running for five minutes. Have replaced the control board already. What does it mean?
Others have had the same question. These urls ( both current as at 2018-02-03)
http://tinyurl.com/yaomkjxo
and
https://www.youtube.com/watch?v=plVN4ssa138
throw light on it.
Consensus is that E61 is a heater fault, in which case nowt to do with the board, but likely an open circuit in the heater element. Easy to check with an ohm-meter. Board diagnostics are correctly saying "I've been on for a few minutes but detect no heating..BAD". Keep the old board - it's likely fine.
Replaced heating element now I get error E61, I ohmed out the thermostat on top of heating element seem to be ok
Hello Louie, I appreciate your inquiry!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E61" after you have replaced the element. An "E61" error code means that there could be an issue with your heater relay or main control board. You may need to seek additional assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
1helpful
I am getting E61 code on my Frigidaire Affinity Dryer model number FASE7073NA, how do I clear this error code?
Good Morning Friend, thank you for your post!
An error code E61 on your Frigidaire dryer is associated with a failure in the heater relay. A qualified technician would pinpoint the problem by checking the wiring for both open and short circuit across heater relay(s). If the wiring isn't the issue, he/she would need to determine whether the problem rest with the main control board. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason.
May 27, 2014 • Dryers
2answers
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
