I bought a Saeco Royal Office machine of ebay and now i cant get into menu because i dont have the PUC code? how do i get by it? Thanks for any help
SOURCE: i have a (saeco) type sup 016 royal proof (app #
Hi, first the water tank must be full. Turn on the power button, wait for it to heat up-approx 2-3 minutes. You must purge the air out of the system by pushing the button for making coffee ,and at the same time you must turn counter-clockwise the steam knob(frother). Until you see a steady stream of water then only your system will be purged of air. Make sure to never run out of water, or you will have to repeat this process over again. You will also have to fill the dispenser with espesso beans. Good luck with purging the air, it`s a little tricky but really worth it when you indulge with a nice shot of Espresso...
SOURCE: Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
