Hello, you will have to remove power cables, and leave for a while then reconnect it and try again. check out my blog for more tips ;
http://diyshelf.blogspot.com/
SOURCE: only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
SOURCE: amber light flashing on my dell 5100, green light on motherboard
The green light just means it is plugged in and getting power.Try pulling the plug, the green light will go out. If you can remove the battery out of the motherboard, "it looks like a quarter", leaveit out for a couple minutes and out it in 'The same way it was" make sure you "look" at it before removing it, it has a little release thatenables it to lock in, or pop out. plug it in and give it a start. It may just be the settings got corrupted, that little battery saves the start settings, once it starts, we can go into the bios if any settings need changing, I'll keep an eye on this post, good luck
SOURCE: Solid Amber light when starting the Inspiron 530
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
SOURCE: I have a Dell Inspiron 530s. It is a year and a
Even it is included in a law suit depends if you want your unit to get back into action or not.You can usually get a dell MoBo of the same model from ebay,newegg or geeks.com for a modest or lower price and even suggest a service tag to come with it.
