Problem
Why is CL ( or C ) flashing in the base message window?
Solution(s)
This indicates that you need to set the time and day on your answering system. During initial setup and any time there is a loss of power to the base, you will see this flashing indicator. Consult your User's Manual for instructions on setting the day and time. Manuals for most models can found on this site. Go to our MANUALS section, then search for your particular model.
Find the button for day,and set the day, find the hour button, set the hour, and find the minute button and set the minute, then the phone will not flash CL
PEO normally means Player Error Optical which means that for some reason the cd player is not reading the cd correctly. This can happen if the disk is dirty or has a lot of scratches. If the disk is clean and in good condition more than likely the cd player will need to be replaced.
You need to reset the time after a power outage.
Press the Day/Check, Hour, and Minute buttons until the correct time is heard-- Press Day/Check until you hear the correct day announced. Then do the same with Hour, and then Minute.
