Question about Lenovo IdeaPad S10-1208Uw Netbook
My netbook wont turn on
Before when you turn on the shutdown automatically
    New Friend:
  • 33 Answers
  • Check wether there is any battery problem...
  • Or else if netbook shows booting screen before shutting down. try safe mode log in... (mostly keep pressing "F8" key, it will show menu..)
Posted on Oct 18, 2012
SOURCE:
1997 dodge stratus wont start has no spark and no trouble codes.
The automatic shutdown (ASD) relay will turn off power to the coil(s) and fuel injectors if the PCM is not receiving a signal from the crankshaft position sensor. You can check the ASD relay, but the problem is almost always a crankshaft position sensor or the wiring/connectors between the PCM and that sensor.
Mar 29, 2017 | 1997 Dodge Stratus
My netbook turns off automatically
Go to www.ebay.com Type make and model of laptop, refine search to motherboard, also! check www.asus.com contact customer support and the technical department.
Jun 28, 2012 | ASUS Eee PC 701 Notebook
1005ha bios update usb
Upgrading BIOS is dangerous and can cause fatal damage to your PC. If you are aware of that and decide to take this risk, then continute. 1. Visit http://support.asus.com/download/download.aspx?SLanguage=en-us, search 1001HA and choose DOS as operating system. Download latest bios rom file.
2. Save and extract the downloaded file. You will get a rom file named like "1301.rom" 3. Format a usb pen drive to FAT-16 partition. In my case I used a 32 MB SD card which came with my old Kodak camera, and I used a SD card reader that PC can see it as a usb disk. Copy 1301.rom to its root folder and rename it to 1005HA.ROM. The reason for renaming it to 1005HA.ROM is that EZ Flash on this 1001HA netbook looks up rom with this name. If EZ flash failed saying trying to find a rom file with another name, just shutdown the netbook and rename your rom file to the required name and try again. 4. Plug in the usb pen drive and reboot the netbook. Make sure that during the ASUS splash screen, press ALT+F2. Then EZ Flash will run automatically and try to locate the usb drive and read from file 1005HA.ROM (in my case). 5. It takes around one minute for me to upgrade everything. DO NOT TURN OFF OR EVEN TOUCH YOUR NETBOOK DURING UPGRADE. Read the messages on the screen and when it says you can press the shutdown button, you can turn off your system. 6. Turn on your netbook again and enter BIOS to check if the BIOS version is up to date.
http://www.youtube.com/watch?v=61awfpVe49k&feature=player_detailpage
Jun 11, 2012 | ASUS Eee PC 1005HA Atom N270 TFT Notebook
When i shutdown my notebook it'll automaticaly turned on. why should i do?
Your motherboard's BIOS may need updating.
1. Plug in AC power adaptor
2. Log in as the Administrator.
3. Download the latest XP BIOS update here.
4. Run the 14cn67ww.exe program
5. Run the flashxp.bat program and wait for the computer to restart automatically.
NOTE: Do not remove the AC adaptor or turn of the computer.
May 30, 2010 | Lenovo IdeaPad S10e Netbook
My Advent netbook keeps asking me to reboot it. How do I do that?
For rebooting your netbook. Click start and then shutdown and then restart. This will reboot your netbook. If it doesn't shuts down press and hold the power key for 5 seconds or more and it will be turned off.
May 23, 2010 | Advent Netbook
Netbook gets stuck "cycling" between shutdown and restart
go to the powermanagement in the control panel. In it check the settings to turn off system when i press, or shutdown the pc after 30 min change it to never, and turn harddisk off to never. and remove the system from hibernation
Apr 19, 2010 | ASUS Eee PC 1000HE Netbook
Acer Aspire One Netbook wont start
i had the same problem, but when i clicked skip file it continued any way... the update installed could of moved a necessary file or folder and now your recovery portion is ruined. i recommend contacting acer through there website. hope this helps
Feb 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
Lenovo IdeaPad S10-1208Uw Netbook Logo
124 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
