I can't turn my camera on,I press the power button,it gives me a whirling noise,the lenses come out(but not all the way),the picture on the screen is blurry,and I can't make a shot,and after2 seconds the lenses come back in by itself.Then it does it again,without me even pressing any button!But I can still view my pictures.But I can't download them on computer,because it still displays an error message D: 5fo8 5e02,and the lenses start moving again.I don't know how to fix it.Please help me.Because I took pictures just yesterday and then it stopped working...
I Have the same same problem , it happens to be the sliding door playing up ....need to take it to a repairer(Olympus) to fix ...hope this helps
DUDE this EXACT problem just started happening to me! and i can't get my photos off either....piece of **** olympus.
I have the same issue and error message. However I was able to download the pictures. When your camera is off, put it on read before starting it. The lense does not open then and there is no error message. you can watch and download you picture just fine. Regarding the malfuntion, I have not find a solution yet. Shop takes me £40 for just checking it within 4 weeks. Hope it helps. Pierre
Exactly the same for me on a 2 year old camera. Have managed to download pictures. I wonder if it is a common fault on the newer verions i.e the MU1010.
Looks like a general malfunction Warranty replacement or purchase a new one - repair I would imagine is not an option.
SOURCE: I have an error messag D: 5f08 5e02 on my screen.
D:
5f08
5e02 THIS FIX WORKS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
BY TRIAL AND ERROR I FIXED MY mju 700 SHOWING THE ABOVE ERROR
IF YOU PRESS AND HOLD THE ok/function BUTTON, AND TURN THE CAMERA ON AND OFF A FEW TIMES WHILST KEEPING THIS BUTTON DEPRESSED, IT SHOULD HOPEFULLY SORT ITSELF OUT?!
(NOT SURE IF IT MAKES A DIFFERENCE BUT MY DIAL WAS SET TO scn FOUND INBETWEEN guide & the wobbly hand.
I ONLY TURNED on/off/on AND IT FIXED THE ERROR, IT MAY TAKE MORE FOR YOU.....I'M NOT SURE AS MINE IS NOW FIXED!
IT WORKED FOR ME, HOPE THIS HELPS, GOOD LUCK!
Mike
SOURCE: I can't turn my camera
The camera may be faulty or it needs to be reset to the factory settings.
Try removing the battery leave it out for at least 1/2 hour, then replace the battery.
If it doesn't work then you need a new camera.
the camera benque dc 2300 cannot be turned on , the battaries are ok , I think it is locked ,give me the solution.
I'm having the same problem with the same error code. Still can view the pictures taken. Any solution for this problem. By the way, my camera is no longer under warranty. Please advise
dito
I'm having the same problem after 2 years of good photo....I need help, il you have the solution thanks
I have the same code and nothing works. I need help. Thanks
Did any one solve this issue ???
