Hi can any one help me my cars heaters have stopped working , it is a Citroen Picasso 2.0 hdi i have read a few things about this and it seems like a common problem but none are the exact same as mine . OK so i have removed the blower motor and tested it with a live feed from the battery and it works , all the fuses are good . few sites mention the resistor this is located with in the blower also my car had the digital controls and all the other functions on the control work fine apart from the blower any one have any idea what i could try or do to fix this please
Hi all. Yes this is a very common issue. 2 distinct issues in fact are common with the aircon.
1 you get fan on certain settings only. This is the resistor gone and johnjohn2 has identified the fix for this above. This is usually (although not always not intermittent and so you will usually lose all other settings over night and they don't come back
2 you get no fan activity at all. This starts to happen intermittently and then gets more frequent until the fans won't work at all. The fix for this is expensive through Citroen but cheap if you get the part off ebay. It is the ignition switch cable which has a fault. A very common issue. You need to remove the ignition switch and replace the cable from it. Work is not long but plugs can be tight and fiddly.
here is the link for the part
http://www.ebay.co.uk/itm/Ignition-Switch-Cables-Wires-PEUGEOT-206-CITROEN-XSARA-PICASSO-Lock-Barrel-Plug-/121038091531?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c2e6eb50b
good luck
SOURCE: remove heater control switch
Before removing the heater switch on this 2006 citroen hdi I would first have the blower motor checked and the most common reason for this and other blower problems would be the blower resistor.
Your blower works on and off at times, first locate the blower motor and the resistor. the blower motor is located on the heater box, look under the pass/side of the dash, you may have to remove under dash cover to see blower.
When you have located the blower now look to the side on the heater box, there you will see a connector plug, it plugs into a connection on the heater box, this will be the resistor, the resistor slides into heater box and the end of it bolts to box to hold it in place and then the connector plugs into it, if you can not locate it then follow wires that plug into blower , follow wires back they will lead you to resistor,
next time blower does not work wiggle connector to resistor and see if blower turns on, if it does then resistor is the problem. also unplug resistor plug at resistor and check for any burning of connectors at plug and inside resistor.
I would bet its a bad resistor or the plug is brunt due to high draw from bad connections, if plug has burn damage to connectors then replace the plug along with resistor.
SOURCE: tyre pressure for citroen xsara 16 hdi picasso vtx
front 2.3bar (33psi)
rear 2.3 bar (33psi)
let me know if this helps
cheers mike
where can i find the blower resistor i have removed the blower and it has one built in is there another one some where in the car ?
