Canon LASER SHOT LBP-2900 Printer Logo
rajkumar bidwan Posted on Oct 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Data transfer to the printer timed out, or a transfer error has occurred.
Only 1 print then error
David Payne
Level 3:
Top Expert:
  • Canon Master 14,162 Answers
  • Posted on Jun 01, 2015
David Payne
Canon Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998425
Points
455836
My Brother printer DCP-T420W shows the Unable Print 49 and also it says that the ink is low when it is not. How to fix this?
"Unable to Print 49" occurs when:
- there is a mechanical malfunction
1. Confirm the error message appearing on the display.
- If "Unable to Print 49," continue to step 2.
- If a different error message, click here to search for that error message to locate the appropriate troubleshooting steps.
step 4.
- If "Unable to Print 49" returns, skip to step 5.
step 5.
Warranty and Service Options.
- If you want to confirm and transfer faxes, continue to step 6.
- If you only want to transfer the Fax Journal Report, skip to step 7.
a. Press Stop/Exit to temporarily clear the error message.
b. Press Settings.
c. Press ? or ? to select Service. Press OK.
d. Press ? or ? to select Data Transfer. Press OK.
e. Press ? or ? to select Fax Transfer. Press OK.
- If "No Data" appears, there are no faxes to transfer. Press Stop/Exit. Continue to step 7 to transfer the Fax Journal or if done transferring skip to Warranty and Service Options.
- If there are faxes in memory, you'll be prompted to enter a fax number. Enter the fax number, including the 1 plus the area code. Continue to step f.
b. Press Settings.
e. Press ? or ? to select Report Trans. Press OK.
f. Enter the fax number, including the 1 plus the area code.
g. Press Black Start. The Fax Journal Report will transfer to that number.
2answers
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
2answers
Canon LBP6000. Data transfer to the printer timed out, or a transfer error has occurred. Click [Resolve Error] to resume printing, or click [Cancel] after pausing the job, then try to print again.
Best to un-install the printer drivers, softwares related to this printer. Go to Canon.com and download the latest drivers and software. Connect the printer to the computer and let the computer recognise it and then install the drivers from your download. You can also check if there is any damage to the cable as this could also stop the communication between the computer and printer.
Sound like Computer Need some serious Maint. Get You IT guy to do the usual comp tools then check for driver errors. You May even have a virus. Run the Tools for You're system. once in a while and You should Be trouble free
I receive the following error message, when I power on my Copystar CS 300ci: Machine Failure C1950 Any suggestions
Transfer belt unit EEPROM error No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively. Mismatch of reading data from two locations occurs eight times successively.
Mismatch between writing data and reading data occurs eight times successively
1. Poor contact in the connector terminals.
- Check the connection of connector YC28 on the engine PWB and the connector of the transfer belt unit, and the continuity across the connector terminals. Repair or replace if necessary.
2. Defective transfer belt speed PWB (inner transfer belt unit).
- Replace the transfer belt unit.
I hope this is helpful,
Shawn
2helpful
I have a HP 9050 Printer that is producing an error message. CODE 4902.4C02
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font.
http://www.fixya.com/support/t6031482-hp_laser
1helpful
I have an hp laser jet color printer 4650n which is giving me a code of 49.4C02 service error
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font.fix printer error 49.4c02
Hope this helps you.
I have a HP 5550 Color printer and I'm getting a Service Error 49.4C02 on my display and nothing will print. What should I do?
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font. http://www.fixya.com/support/t6031482-hp_laser
2helpful
Printer is not printing
well you have to load the cd the printer came with onto your computer than go to options and see if it showed up than it should work
old marine
old marine
ZJ Limited
ZJ Limited
