SOURCE: how do i replace the inner glass on the oven door?
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: PS2087058
SOURCE: KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
SOURCE: Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
SOURCE: broken inner glass on Model # NGSG3PZAQA
3Removethe
I also report testimonials for your model:
"removed the door from the
oven by releasing clips attached to the door hinge -- very nicely
engineered. Removed about 6 philips head screws to allow the door
assembly to be taken apart for access to the glass. Lifted out the
broken glass, cleaned the inside of the door, installed the new glass,
reassembled the door (a two minute project), and reattached the door to
the oven. Cleaning the inside of the door"
"I removed the oven door by
lifting it off with the hinges. Disassembled the door parts one at time
making sure I remember where I removed the screws until I am able to
get to the broken glass. The most difficult part is making sure that
the insulation strip & the gasket stayed in place after I replaced
the broken glass & doing the reverse process of installing the
parts together. Relatively easy process as long as you remember where
the parts go. When in doubt, I had to refer to the pictorial of the
disassembled door shown on your website.
Part here: Inner Door Glass
