Frigidaire GLTF1240A Front Load Washer Logo
Posted on Jan 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a front loader frigidaire and it wont drain or spin
  • Jeff Meyer May 11, 2010
    Are you still having problems with your front load washer?
    What was done to fix the problem?
orzechoski
Level 2:
  • Expert 77 Answers
  • Posted on Apr 26, 2009
orzechoski
Expert
Level 2:
Answers
77
Questions
0
Helped
30186
Points
166
Pump blockage, or drain pipe blocked.
Frigidaire Model:22S750 machine will wash wont spin dry clothes
Its usually a door lock problem, motor control board, or drain pump issue on front load models. if its a top loader model its probably your lid switch.
Front loader washer wont spin but will wash
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
1helpful
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
3helpful
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
9helpful
2answers
Front loader, will not spin at high speed drain
Drain strainer on output side of pump could be clogged a little.
1helpful
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
3answers
Frigidaire front load washing machine gtlf490e
ill save us some time that washer is one of the best out there i have one my self pop me an email at [email protected] and check my4 boxes say in e mail front loader wont spin ill send ya something
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
