Canon ZR300 Mini DV Digital Camcorder Logo
Mark Nieshalla Posted on May 07, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon ZR300 record button no longer works
05/07/2007 - I own a Canon ZR300 camcorder purchased in April 2005. The start/stop record button on the camera no longer works. Usually when you press it the camera makes a small ding noise and begins or stops recording. When I press the button now there is no ding noise and recording does not start. The camera DOES record when I use the remote to start or stop recording. Seems like all that is needed is the button to be replaced, and if so, how much would Canon charge for that service? Any ideas?
  • RIOSTOUCH54 Dec 31, 2007
    record boutton doesnt start when depressed
  • Anonymous Mar 18, 2014
    putting camera onto play VCR press the focus button film starts to play. when trying to move the forward button or the reverse button no good. start from the remote control OK
Mohamad Abdan
Level 2:
  • Expert 71 Answers
  • Posted on May 08, 2007
Mohamad Abdan
Expert
Level 2:
Answers
71
Questions
Helped
20749
Points
116
Hi sir just two things to do first 1- restore to factory setings from the menu and check if it is solved 2- if not just try to see does the knub is in its reguler state if yes so you need to replace it
8helpful
Canon ZR300 Mini DV Digital Camcorder THE MINI DV TAPE IT DOES NOT GO INSIDE THE CAMERA, SOUND LIKE IS GOING BUT IS EJECTED WITH A AUDIO WARNING AND IN THE VIEWFINDER SAY REMOVE THE TAPE AND A X APPEARS,...
I know this is going to sound strange. I had the same issue with my ZR300. When you insert a tape and close the mechinism you hear the tape whirl then it pops open and chimes. I found a solution online and thought it was to good to be true. It said to hold the camcorder in your left hand with the right side up (the opposite side of the fold out viewer). You then hit the camcorder , not real hard like slapping something. Open the door and insert the tape and WHAM! It loaded fine. Eight people had tried it according to the review and all eight people had success. I was skeptical but it works! Don't hit it so hard you break it. I did mine twice before it worked but it works everytime now. Trust me just try it and it will work.
2answers
Canon zr300 ejects tapes
hmmm...the only reason that usually happens is when the tape is messed up internally, or there is something stuck in amongst the head
What does wrong format mean with a canon zr300 camcorder? My buddy shot some footage on a high end camera and my zr300 camera at playback reads "wrong format playback not possible.
Different camcorders have different recording formats. Some ar HD, some are 16x9, etc.
A camera that isn't designed for a particular pre-recorded format cannot playback that recording.
Rick
Black bars on zr300
Cleaning Tape did the trick. Thanks!
Andy
http://www.fixya.com/support/t985270-cassette_loading_problem_in_canon_zr200
I "smacked" my ZR300 as instructed on this site and it worked. Good luck!
littlequeen
Making noise
I would take that into a repair and have someone look at it. It could be serious.
3helpful
10answers
Hi guys,
Thank you very much for this solution posting. Really it worked. I was about to buy another one instead of fixing the problem. Because you know how the pain is, to send it factory and getting it repaired.
Once again Thank you.
12helpful
8answers
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
2helpful
3helpful
7answers
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
