Frigidaire PLEB27T9DC Electric Double Oven Logo
Posted on Jan 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven door won't open on frigidaire electric range ES200/300
I inadvertently locked the oven door, now it won't open. I have tried disconnecting it for 30 seconds or more but it still won't open, what can i do?
Anonymous
Level 3:
  • Master 750 Answers
  • Posted on Jan 01, 2009
Anonymous
Master
Level 3:
Answers
750
Questions
0
Helped
490935
Points
2063
Turn the power off at the breaker box for five minutes.
this will reset the system of any electronic glitches.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
3helpful
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
7helpful
2answers
F9 Flashing on Frigidaire 30" range
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Oven door locked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$%!!!%!%
1helpful
F9 code comes on frigidaire stove when self clean operation starts, i cleaned around door lock, what should i do next
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#!#
Try to use selfcleaning feature on range and as soon as door locks it stops and goes to F9
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%
Llock light is on but door will not lock to clean oven
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$%^&
Self Cleaning problem
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question)(*&^%
Self Cleaning error F9
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
