Model HD211B clock radio; Auto set digital tuning alarm clock radio maintained by SDI technologies
1: Remove screw from top back of radio and carefully lift lid that retains buttons. Might be a good idea to take a pic of buttons so they don't get mixed up as they will just pop off at this point.
2: On either side of the back middle button you will see a switch and three (3) buttons.
3: Move "Off On Lock" switch to "Off" (left) position. You will see the unlocked symbol appear on the display.
4: Push far right button first to set your time "Zone" using the "Alarm Time" or "Radio Tune" buttons. Wait 5 seconds for the beep when done.
5: Push the "Time Set" button. (It is the one closest to the "Off On Lock" switch).
6: Use the "Alarm Time" or "Radio Tune" buttons to set the time. (Note: "PM" will appear in the upper left corner of the front display when your time is after noon!)
7: The time display will stop blinking and set about 8 seconds after your last move.
8: Push "Calen" button to set calendar. First the year the push the button again to scroll to the date.
9: Push the lock switch to the right and the lock symbol should disappear from the front display.
10: p
If you removed any buttons put them back, then put the cover back on and re install the screw.
or
Call the front desk and ask them to set or replace the clock.....
SOURCE: How to set time/alarm GE Auto Clock Set Radio Model 7-4892A
I have a solution for the GE Auto set clock and radio model number 7-4892A. The only way that I had found out just by accident is that you are suppose to hold down the manual clock set until you start to see the Year and then the Date. There you will be able to set it to the correct date or year.
Idea from
Guest
Installation
1* Remove unit and all packing materials from the carton. You should save packing
materials in case unit needs to be returned for service. If you do not wish to save the
materials, please dispose of them properly.
2* Place the unit on a stable, level surface, close to an AC outlet, out of direct sunlight,
and away from sources of dust, dirt, heat, water, moisture, vibration, or magnetic fields.
3* After installing the batteries (see below) and reading the Maintenance notes, plug the
AC cord into an outlet.
"Sure Alarm" Battery Backup Installation
It is strongly recommended that 2 "AA" batteries be installed into the unit, as directed below,
in order to activate this product's "Sure Alarm" Battery Backup feature. (The model should
come with two batteries already installed.) In the event that the AC power cord is disconnected
or a power failure or other interruption occurs, the "Sure Alarm" Battery Backup will maintain
clock and alarm settings for the life of the battery, ensuring that the alarm (buzzer only) will
sound at the set time. During any interruptions the time and alarm settings will be saved
and automatically restored when AC power is again active.
1* Gently turn the unit over and remove the battery
compartment door.
2. Install 2 "AA" batteries (alkaline is recommended for
longer life), while making sure that the + and - ends
match up with those inside the battery compartment.
3* Slide the battery compartment door back on, making
sure the door locks into place, and gently return the
unit to its upright position.
