Cars & Trucks Logo
Posted on Jan 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frozen pcv valves
How do I keep the pcv valves from freezing on 2003 dodge 1500 with 4.7L eng. This happens @ around -35C. When they freeze it pressures up the crankcase and blows all the eng oil out.
Anonymous
Level 3:
  • Master 512 Answers
  • Posted on Jan 01, 2009
Anonymous
Master
Level 3:
Answers
512
Questions
0
Helped
340928
Points
1457
Contact your local dealer. there is a technical service bulletin tsb 25-002-08 that give a list of parts to repair this situation and a description of how to do it
Where is the PVC valve location for a 2001 dodge Dakota SLT 3.9 v6 eng
The PCV valve is inserted into a grommet in the left side valve cover with a hose running to the intake manifold. On the right valve cover is another hose running to the ducting from the air box to the valve body - the PCV valve is not on this side.
Frozen gas line
I'm assuming you got this fixed already but to prevent it from happening again keep fuel more than half tank and with every fill add a fuel additive that prevents freezing
Check enging light is on my 2000 pontiac grand prix
Hi there:
Are you ferer at DTC P0410 - Secondary Air Injection System Malfunction
If this is right, this code refers to the emissions system. The AIR pump puts air to the exhaust to lower emissions. It takes in outside air and pumps it through two one-way check valves into each bank of the exhaust.
About 90% of the time that this code is set, the one-way check valves have worn out or failed and allow water (which occurs naturally in the exhaust) back into the pump. In any cold climate, especially in climates with higher humidity, this water may be more excessive. The water partially fills the AIR pump, it can then freeze. When the PCM commands the pump on, if the pump is frozen it cannot turn, thus overloading the circuit and "popping" the fuse.
A code P0410 may mean that one or more of the following has happened:
Water may have collected in the AIR pump or the vent solenoid and frozen or corroded the pump
Blown AIR pump fuse due to freezing up
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Hard cold start for 99 intrepd w2.7l/ ok hot/set check eng lite
Check your Fuel Filter, especially if your in a cold climate that has already reached freezing temps. If you have any moisture in your fuel system and the freezing temps have arrived the filter and injectors can freeze up slightly causing this type of problem. If this was happening in warmer temperatures check the fuel system for pin hole leaks that could be allowing the air into the system.
1helpful
2answers
Where is the pcv valve located on a 2005 dodge ram 1500, 4.7 ltr eng
looking at the engine from front it should be in the right valve cover. a hose comes from the pcv valve to throttle body.to replace it, just pull up on valve to release from rubber grommet. have a good day !!
2answers
Need location for pcv valve
should be in the passenger side valve cover.
PCV Valve escort 98
it might had small hole drilled in it to help with air flow during those extreme cold tempertures
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
