There are a few reasons why a battery won't charge. Make sure that the contacts on the phone and the charging cradle are clean. (Unplug the base or charger.) A pencil eraser is good initial cleaner; electronic contact cleaner sprays are a second option. Remove the battery and check the contacts inside the handset and the battery as well. Next replace the battery pack. If you add a comment with your phone's model number, then I can try to find the correct battery. (Stores like Battery Mart may have a compatible battery.)
The final possible problem is that the charging system is bad. If your phone has multiple handsets, try a different charger. If the phone allows you to add handsets, try getting a new handset. The new handset will come with a new charger. (I've never seen the chargers sold without the handset but you could try Uniden customer service. If the base station is the only handset cradle, you'll probably need to replace the phone if a new battery and clean contacts don't work.
If your Uniden phone is under warranty, contact the company.
if you dont have the original charger, the 750 take a special car charger because of the traffic feature...it has a flat end about 3/4" to 1" long that fits in the cradle, but you can use a garmin usb charger, you just wont be able to use the traffic feature.
if thats a little confusing ( i tend to do that) i try and explain it another way.
if you think you need or want one of those chargers, just post back to me.
1st of all let me say im on my 3 cradle now for my 760 because the connection inside the cradle where it mounts to the board is pretty poor.
since you said the traffic/charger has the green light lite, that means the charging part of it is working.
you can verify if its the cradle or the connection on the bottom of the gps where the cradle mounts by using the usb cable supplied with your garmin.
plug it in for a while, then check the battery meter after you unplug it..if its charging, the meter would have risen beyond what it was before you tried to charge it. the same can be done with a regular garmin charger (the one that uses the usb connection for the car charger to charge it)
I would guess that the battery is not being charged. The problem could be poor connections between the charger & Camera or between camera and battery; or the battery no longer will take a charge.
First, clean the connections with the eraser end of a pencil. Clean the connections on the Charger and on the camer; clean the battery connections and in the camera, Charge overnight. If this does not get the camera working, borrow a battery and see if this works.
For charging your Samsung L201, you need the ac adapter (part number AD44-00131A, style SAC-47) and the 20-pin usb cable (part number AD39-00147A, style SUC-C3) both of which can be ordered at www.partstore.com
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
It seems your charger port is broken, it hapfens often on cellphones, wear and tear. Check to see if its under warranty, and it can be replaced. Check my profile if you need more help.
You Blew A Circut In the Charger Port Depending On the wattage of that wrong charger. Now HeresWhat you do. you Need to find out if you blew all the circuts in the phone or just the one for the charger port, Find Some One With A Sidekick Test the battery in your phone make sure its fully charged, If your Phone Comes on the rest of the circuts are fine, if it doesnt you need a new mother board. If It Does U Need To Have the Phone Repaired. Call Me 347.845.7151
PLz Be Sure To Mark The Problem Solved
