My washing machine would not go past the spin cycle, after the rinse cycle the water stay in and it cut offMy washing machine would not go past the spin cycle, after the rinse cycle the water stay in and it cut off
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
if you unplug the washer does the water continue to enter? if the answer is yes you have a bad fill valve. is it only when you use cold water? what is the model number?
your using way to much soap
during that whole 1 minute cycle it is detecting suds and trying to rinse the cloths further
cut way down on the soap here
you should be using 1 tablspoon per load
wash one load without anyy soap at all
this should help to reduce your suds lock
While the machine is operating take the timer knob and wiggle it around. If the machine cuts out momentarily then the timer is bad. If not then I would check out the lid switch to see if it is affecting the rinse and spin cycle. Eric
the machine is several years old and may have multiple problems one could be the timer since it is not cutting off, and either a problem with the water pump or something blocking it
probally time for a new washer
how do I know if the lid switch is not working?
