SOURCE: How to set time in the citizen ecodrive skyhawk
http://www.citizenwatch.com/Technical/English/Abbreviated/C650_condensed.pdf
A correction from the last post, you don't need to do All RESET. Read the section right below that. You put the needle on CHR, pull out the dial and set calibrate the hands without resetting the whole thing.
SOURCE: watch
You should be able to pull the crown out 1/2 way and turn the crown clock-wise and you should hear a click and the calender should move one day. Don't change when the hands when the time is between 10 and 2 , just manually move the hands past that time , and re-set afterwards. If that dosn't work let me know ,.There are other types of those watches , but the way I told you is the most common.
SOURCE: how to adjust time of men's citizen ecodrive c 8700
Check my tips. Complete Citizen manuals are there.
SOURCE: need instruction manual for citizen 3100 calibre watch
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
