Question about Symphonic ST420FF 20" TV
Symphonic WF20L6 20" TV
Television comes on and then goes off after just a minute or two.
  • 12 more comments
  • saqerhussein Nov 06, 2007
    is the same problem comes and goes off less than2 seconds
  • JasonEMT Dec 02, 2007
    TV turns off after about 30 seconds.
  • Cynco Dec 12, 2007
    I am having the same problem with the tv turning off after 30 seconds. What has anyone done to get this problem resolved.
  • scran Dec 16, 2007
    I have the same problemw with the T.V. Has anyone found a solution to the problem?
  • Anonymous Dec 21, 2007
    tv goes on then and then stops working
  • Anonymous Mar 10, 2008
    TV comes on within two minutes, the sound is gone and will
    not come back on. By the way, this set was given as a
    Christmas Gift December 2007.
    NEED HELP BADLY!!!!
    Willie M. Burton
  • pjfrific Mar 11, 2008
    I am having the same problem. My TV is just over a year old when it started this. It comes on fine. After just a couple of minutes it goes off. I can turn it on again, but it stays on just a few seconds before it turns off again. It does this repeatedly. It will NOT stay on. My opinion is that something is getting hot and shutting it down. A friend suggested i get one of those compressed air cleaners to blow it out in case there is any dust in it, but I have not tried that. Hmmm...i was hoping to find a solution on-line. This is sad- obviously a faulty TV. This was a WalMart after Thanksgiving special in 2006.
  • hallslawn123 Jun 20, 2008
    tv will only stay on a few minutes then goes off.
  • talkinterry2 Sep 08, 2008
    Power problem apparently a common problem with this TV. I also bought at Walmart at the end of 2006. Has anyone actually found what the real problem is?
  • Anonymous Dec 17, 2008
    tv turn off after 30 seconds...help??? Is this the inverter as well?
  • Anonymous Jan 05, 2009
    Warranty expired....after a year finally gave in and took it to get fixed....should cost $120.....been waiting on part about 3 weeks....supposedly coming from overseas....will post when finally resolved
  • ejtiger914 Feb 03, 2009
    TV comes on for less than a minute and goes off, I brought it to the tv repair shop & received estimate for $100 with 90 days warranty only & no gaurantee as how long the inverter might last. I am not sure I want to spend more money on it, I bought it from Walmart two years ago.
  • Roscoe007 Feb 14, 2009
    same here
  • Anonymous Mar 11, 2009
    TV comes on for 10 sec then shuts off. pls help!
Easy fix!!!!!!! CUT JUMPER 300 on main board _ [FACTORY DEFECT] protection jumper
If you have a warranty take TV back to store if not easy fix.
Posted on Jul 26, 2009
  • 1 more comment
  • johnandre001 Jul 05, 2011
    That worked great thanks for the help!!
    Andre
  • Pgskr8 Feb 21, 2012
    I just tried this and the TV doesn't turn off now! Thanks . I wonder, what caused it to begin with and is there a fire hazard now or any other potential issue?
    Thanks Shonbrie
The problem is on the inverter's voltage regulators. Zener diodes labeled d808/9 and npn transistors (any of 11) c3199. Also on the mainboard burnt out 12v supply to inverter. Anyone brave enough can disconnect the inverter and tv won't switch-off by itself. Funai made a gaffe in the design of several LCD tvs.
Posted on Sep 10, 2008
  • 979 Answers
Power supply faulting for internal problem..accordianman
Posted on Oct 20, 2007
I suggest to change transistor K3869 and Capacitor Ceramic B 1c2k 2kuv sec that is in front of transistor
Posted on Jun 24, 2008
Problem is on inverter board-D308 zener diode{6.2v]
Posted on Jun 21, 2008
SOURCE:
Is there a microprocessor/software reset procedure?
Simply disconnecting power for a period of time should reset it. I would do so over night.
Aug 15, 2016 | Symphonic Televison & Video
ST413B. Is this model digital?
Unsophisticated is the first word that comes to mind when describing a television like this one, making it an ideal choice for those who want something they can use to watch television but don’t care about anything else.. Without cable input, there is little hope to get the picture looking sharp and clear using an ordinary antennae. IT IS NOT DIGITAL AND RUNS ON the old RABBIT EARS.!
Jan 28, 2010 | Symphonic ST413C 13" TV
I DO NOT HAVE THE ORIGINAL REMOTE. THE TV IS CONNECTED TO A SATELITE FEED. AFTER A FEW SECONDS ON SOME CHANNELS THE SCREEN GOES BLANK AND A MESSAGE COMES ON "PROTECTED TV PG-14" IS AN EXAMPLE. HOW DO I...
walmart sells a ge universal remote in the check out it is a three in one remote. for five bucks. it does everything i own. except a twenty five year old tv. it will even access the menus on my ac unit.
check it out. you may have to use the manual program mode on the thing but it will probaly work
Mar 12, 2009 | Symphonic Televison & Video
Television shuts off by itself
TRY THESE STEPS
>Check the buttons on the TV make sure they are clean and not sticking.
>Check the Remote Control buttons and see if they are sticking
>Clean the Face of the infer Red lens to the remote and the TV...
clean them with a small rag or paper towel (Do Not USE Abrasives to clean any part of your Electronics)
>Check the plug for any defects
>Reset your tv back to it,s factory settings
>And if any thing locate your user manual and find the 1-800 number
Aug 29, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Symphonic 32" lcd flatscreen tv
Assume that the electronics board inside the TV maybe cracked in that the electricity is NOT going to or coming from someplace important.If u know what u are doing [no offense] check to see if any of the buttons have been pushed from the outside.Sometimes difficult because they are usually s.p.s.t. [single push single throw] in other words "push on,push off".str8cowboy, ANY button that is stuck can effect the TV.
Apr 27, 2008 | Televison & Video
Symphonic television has no sound
It's probably either a defective speaker, or something defective in the Audio Amplifier stages. If the set has an audio output jack, you could try plugging into a small stereo and see if that gets you by.
Hope that helps...
Geno
Apr 04, 2008 | Symphonic WF20D4 TV
check ur power suppy stabilizer,t.v smps .complaint is dry soldering. resolder ur t.v board.(bottom) .any complaint E-mail-alphabinu@yahoo.com.
Feb 25, 2008 | Televison & Video
TV PROBLEM
turn caption off
May 15, 2007 | Symphonic ST419E TV
Symphonic ST420FF 20" TV Logo
1,704 people viewed this question
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
