My tv will not turn on - the power button is blinking red six times in a row and then stops.
My TV KDF-E60A20 is now Fixed. My tv was overheated and Thermal Fuse Located bottom of the lamp burned. I replaced a different Thermal fuse part from 191000644 to 191002393
at www.partstore.com
search for part number. thank you for the review it's help me a lot
thank again
In the manual it says call for service
This is a low b error. the thermal fuse needs to be replaced.It happened to me
SOURCE: KDF-E60A20 Red Light Flashing 6x
a 6x blinking error code is usually the thermal fuse located above the lamp housing on the light engine. probable cause of failure is clogged fan located in same area or poor ventilation because set is to close to wall [unit requires minimum of 4 inches of clearance]. part # is 1-910-023-93. another possibility but less likely is the gm board which drives the lamp voltage. part # is a1109407a.
my tv have the same problem after 2 years from now , tv on 12 hours straight then it turn off automatically. I though the lamp is bad, ordered new lamp still doesn't work. do some research. i see many people have thermal fuse is bad. can any one show me how to fix it, or buy thermal fuse at. here is my tv model: sony grand wega 60inch projection KDF-E60A20 . please reply me at [email protected]. thank you very much.
same problem 6x blink red
KDF-E60E20 same issue 6 blinking red light pattern out of no where. Found some research matching the fuse suggestion but no info on how to actually fix the problem. Please help!
where to get a thermal fuse 191002393 to send to canada..?
please help...thanks
Same problem. I owned the TV for 2-1/2 years with no problems, now this. Anyone know if it is difficult to replace the thermal fuse? Any instructions on how to do this?
i have the same problem with my sony tv kdf e60a20 don't have a clue on how to fix it and i would like to know where to get the fuse from and did it work at all!!!!!!!!!! some one help plzzzzzzzzzzzz
red light blinking six times
