Black wire is burnt, the black wire attaches to the second (lower) oval-ish shaped part on the front of the heating element. The little metal connector is burnt and corroded looking and the wire is VERY obviously burnt about 2inches down. The rest of the wire looks fine. Is this burnt wire cause by an issue with the heating element or is it caused from a bad wire/connector? I need to know what I need to replace.
SOURCE: I have a Maytag
Okay have you replaced the wire with with the correct one? If the wire gauge is wrong it will do every time next you need a volt meter with a buzzer sound maker on it test your thermostat and hi limit thermostat if it makes a noise when testing its working. Only thing that would cause that wire to keep burning are those options and if all checks out okay then its faulty wiring which is grounding out somewhere which is a pain to trace and if you might not find the bad wire had a few of these with these problems and I ended up junking them big fire hazard sorry for the problem.
It's the original wire that came with the dryer. I don't have a volt tester. This issue isn't caused by the heating element, but rather by the high limit thermostat? I've had the dryer for 4 years now and have never had any issues with it, so I'm assuming the HLT is the issue, unless grounding issues can occur after years?
Replaced hi limit thermostat and fixed the wire using a 12G wire from Lowes, got the right disconnect pieces at Radio Shack for 2.19, and fused the wires together using heavy duty **** connectors. Seems to be working properly now.
