My i pod is stuck in a different language
SOURCE: cant read this language
Try plugging it into your comp, bringing itunes up, and resettings it back to its original factory settings.
SOURCE: language problem
1. Scroll to the second to last option, press select.
2. Scroll to the third to last menu option, Press select.
3. Select English from this menu.
Hopefully this helps. Here is apple's site on it:
http://support.apple.com/kb/HT1824
SOURCE: Ipod in chinese dont know how to switch back to english.
If you accidentally set iPod nano to use a language you don’t understand
You can reset the language.
1 Press and hold Menu until the main menu appears.
2 Choose the sixth menu item (Settings).
3 Choose the last menu item (Reset Settings).
4 Choose the first item (Reset) and select a language.
Other iPod nano settings, such as song repeat, are also reset.
Note: If you added or removed items from the iPod nano main menu (see “Adding or
Removing Items on the Main Menu” on page 11) the Settings menu item may be in a
different place. If you can’t find the Reset Settings menu item, you can restore
iPod nano to its original state and choose a language. See “Updating and Restoring
iPod Software” on page 69.
Good Luck and Please Rate FixYa!
