Question about Whirlpool LGB6300 Gas Dryer
Drum hitting dryer top
When pressing dryer top or placing basket on dryer top drum seems to be hitting top
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Sounds like the bearing seals may be getting worn. You will need to open the top of the dryer and look for wear marks.
Posted on Oct 18, 2012
SOURCE:
Squeaky dryer.
Mice? I doubt it. It is more likely the drum or belt on the drum pressing on something next to it. Pull out the machine from the wall, unplug the machine from the power outlet and open the top back panel. Look inside where the drum is and see if there are scratch marks where the drum appears to be hitting or the belt scraping. Pull out the lint that is all over the place while you do this.
Jan 23, 2013 | Dryers
How do I Disassemble a GE Profile Dryer to replace Drum Bearings? Model: DPSQ475ETOWW?
remove 4 torx screws from the top of control panel,then slide control panel sideways till you can lift it up off the top cover,then open the dryer door on the upper door land area there are 2 screws going up into the top cover remove them then you can remove the top cover,then on each side at the top there is a screw holding the front panel in place,remove these then you can remove door switch wires from the door switch and lift up on this panel to remove it off the gussets on the bottom of the door,then you can install the top door bearing and 4 drum slides
Nov 29, 2012 | Dryers
My dryer squells through the entire cycle.
You will need to replace the dryer belt. To do this follow the instructions below
  • Disconnect the power for your dryer before beginning any work. It can be disconnected from the wall outlet.
  • 2
    Open the top of your dryer cabinet and tilt it backward.
  • 3
    Use a Phillips head screwdriver remove the top two screws. Put the screws in a safe place.
  • 4
    Tilt the front forward and roll the belt around the drum.
  • 5
    Remove the old belt by lifting the drum slightly in order to give way to the front supports. You may have to open the dryer door to help the belt fall to the bottom of the basket.
  • 6
    Position the new belt by aligning it in the correct position before beginning to thread it through the motor pulley and idler. It will take someone with strong fingers and skinny arms to be able to get past the drum in the front. The dryer belt in a General Electric dryer has to be threaded looking in from the back.
  • 7
    Reassemble your dryer by replacing the screws in the top of your dryer.
  • 8
    Close the top and slide the dryer back against the wall.
  • 9
    Reconnect the power to your dryer by plugging the cord back into the wall outlet.
  • May 02, 2011 | GE Dryers
    Dryer is making a loud banging noise.
    there are bushings or rollers at the front of the drum that do wear out this will cause the thumping as it turns. A local appliance repair place may be able to source out new guides for you.
    Feb 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
    My kenmore elite HE3 elec dryer, model # 11082826101,has a loose piece in the dryer drum, how do I take the top off to fix it?
    There are three screws that hold the top panel in place in the rear of the dryer. Remove these screws and the panel will slide back, then lift off. You should have access the outer perimeter of the drum, control board and control panel.
    If you need to access the dryer bottom cabinet, remove the lower toe panel directly below the door. The panel comes off by removing the screws under the bottom front edge. With the screws removed, the panel will drop down and then come off.
    NOTE: Propping the two front feet of the dryer up can offer better access to the toe panel screws ( a section of 2x4 works well for this).
    There are some helpful exploded view diagrams you can use for reference at these following websites:
    searspartsdirect.com
    appliancepartspros.com
    pcappliancerepair.com
    Small items (like coins) can often get caught in the dryer drum baffles. They come off easily by removing the screws that hold them on place around the drum perimeter.
    CAUTION: Make sure you UNPLUG the dryer before servicing anything inside the cabinet. Dangerous voltage is still present even with the dryer turned off.
    If you have any questions, or require additional assistance, please let me know. I hope this helps you.
    Oct 14, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Drum in kenmore top loaded washer is moving freely, loud in spin
    YOU HAVE RUBBER WHEELS THAT RIDE ALONG THE BASKET HOW OLD IS THE DRYER MAY NEED TO REPLACE ESPECIALLY IF IT IS A OLDER MODEL
    May 03, 2009 | Kenmore 24632 Top Load Washer
    Dryer bangs and jumps
    belt and /or rollers could be the problem at least that is where I would start.
    Dec 30, 2008 | Dryers
    Thumping while drum is turning
    probably is remove console screws and lift console up turn power off first after lifting console remove the 3 screws along back edge slide top forward and off resore power and try ..top may ahve been bent down during move not much clearence between top and drum
    Jul 18, 2008 | Kenmore 63942 Dryer
    Kenmore 40922 front load
    This advice from Sears to replace baffles only applies to dryers. The baffles for the washer are installed from inside the basket. If you can't locate mounting from inside the basket, then the entire basket/tub will have to be removed and disassembled.(big job)... But I am pretty sure they mount from inside. Washer or dryer, there are three screws in the rear along the top. Remove screws, slide top toward rear and lift off.
    Jun 07, 2008 | Kenmore 4292x Front Load Washer
    Whirlpool LGB6300 Gas Dryer Logo
    52 people viewed this question
    Top Whirlpool Dryers Experts
    Craig Butler
    Craig Butler
    Marvin
    Marvin
    Smitty
    Level 1 Expert
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
