I purchased the zipper foot from the Singer website so I know it is the proper foot. The user manual that came with the machine provides no instructions as to how to adjust the needle position right or left nor does it give any instructions relation to the use of a zipper foot. With the needle locked in the center position, it hits the metal of the zipper foot. I need to adjust it to the right position in order to use the foot properly and not mess up my sewing project.
According to this manual (pg 52):
http://www.searspartsdirect.com/partsdirect/user-manuals/3116-SINGER-SEWING%20MACHINE-manual
the zipper foot position is adjustable, not the needle position.
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
SOURCE: singer simple comes with limited feet have been unable to find
janome machine feet should fit
SOURCE: my 8280 modle singer: I sewed a zipper for a
If you are not able to free this easily, you really should consider taking it to a service technician to look at it in case you do more damage to the needle bar and elsewhere trying to fix it yourself.
SOURCE: I have a new Singer 1507 sewing machine- needle position wrong
Turn the big knob on the right of your Singer 1507 machine so that the vertical stitch line in the center. (Currently your machine most likely has the vertical stitch line to the left.) Don't push your needle manually; you will damage the needle.
Look at your zipper foot, you will see 2 bars one right and one left. Attach it as to which side you need for your zipper.
