See this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER"
and "QUICK START" buttons in rapid succession. The "RESET" button can
also be used, in place of the "Stop" button.
thanks for the reply I followed the steps but nothing happens the treadmill do not execute commands,the only command that is run when I insert the code 919 but the functions are limited,I find on my display only those buttons (stop, start-enter, clear-pause) (fat burn,cardio,random,hill,random,fit test,manual) tr 9100 hr ser.no 359211 - 9733 -ok26-1904-002-m051-00206d000
go to www. fitness.manualsonline.com and download your instru.manual, or i am giving my email [email protected] for to send you instr , please send me the yours.God bless you
thanks email sent
o.k .
I HAVE DONE NOTHING BUT THE PROCEDURE
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
SOURCE: I have a life fitness treadmill and put new wax in
you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
SOURCE: FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
SOURCE: Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
