Its a big problem to this pretty camera, hungry for solution...thanks!!
SOURCE: Outdoor pictures reveal white on LCD screen
The sensor for the auto-ISO may be working incorrectly. Try changing the ISO manually for different light modes. You can also try to change the white balance of the LCD. -Setting the white balance: 1. Set the camera to still image mode 2. Press the "Set" button 3. "White Balance" should be the current selection 4. Press the "Flower" button or "Flash" button to move through the available options for white balance 5. Press "Set" again when change appropriately - Setting the ISO: The higher the ISO value, the less light the camera needs to make an exposure, allowing the same exposure to be achieved with higher shutter speeds or smaller apertures. In a digital camera, higher ISO value allows higher shutter speed, at the expense of mottled or grain appearing in the final picture. 1. Set the camera to Still Image mode. 2. Press the "Set" button. 3. Press the "scn" or "timer" button to select ?ISO?. 4. Press the "Flower" or "Flash" button to select the desired setting. 5. Press the "set" button to select. 50/100/200 In the same lighting condition, the higher the ISO value is, the faster the shutter speed will be. I hope this helps.
SOURCE: pink polaroid i631 camera
Hey, I had kind of the same problem; only the lens would not close all the way and could not zoom out all the way. It's my 8 yr old daughter's camera and she must have dropped it or something. I wiggled the lens around a bit (with quite a bit of force) and it popped back into place and is now fine.
SOURCE: polaroid camera 1739 has black spots on picture
you should be able to clean the exterior of the lens with a clean microfiber cloth or lens cleaning papers (available at even wal-mart). If the spots are in the inside of the lens body, you have to send this in to be cleaned as the camera will have to be disassembled to do it right.
SOURCE: file error/polaroid camera polaroid t1031
I have the same camera and that happens to mine sometimes. That happens when something wasn't right when you took the picture. If you press the delete button while it has the "file error" on the screen, it will delete the file and then you can continue use with your camera. Sometimes when this happens it freezes the camera so you have to turn it off and back on, then try deleting it. I hope this helps you!!
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens is little bent to the side. I want you to put pressure on the cam to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
Vicent
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
