Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Electrolux model by clicking the link below.
Zanussi Electrolux DX 6453 Manuals
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
SOURCE: I have a Zanussi DX6453 dishwasher. Water will
Try tipping the dishwasher back to see if any water drains out from below if there is water present then the anti-flood device is energised and stopping water coming into the unit.If it works now after resetting then there is a leak under the machine that needs investigating.You can try going into the diagnostics to read the alarms.If you hold in the first and third button from the left on programmer,whilst holding in then press the on/off button then when the lights start racing release these 2 buttons.You should now be in the diagnostics,now press the first button once and count the flashes of the end of cycle LED.If this button is pressed 2 more times it will give the previous alarms.1 flash could indicate fault on inlet water and valve.2 flashes drain circuit blocked.3 flashes anti-flood device.8 flashes faulty circuit board.Make sure after reading alarms to switch off unit then on then off to reset.Then go back into the diagnostics as before to reset alarms but this time press button 2 from left all LEDS will flash after exit as before.
Hope this helps.
SOURCE: I have Zanussi DX6453 dishwasher.
sugget the water temperature, it relies on the temperature of the water to heat to items up so that when the wash cycle has finished the heat will dry them. Hope this is useful. Regards Mike
SOURCE: user manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
SOURCE: zanussi dx6453
You may have a problem with the cut-off switch that activates when the water fills the tub and lifts up the float.
