I had to format my Hp Pavilion dv6000. Then i installed windows xp. i downloaded all the drivers. and in the "imaging device" the only device listed is USB video device... i already installed the driver Hp provides for built-in web cam, but still it doesn't work. when i open HP webcam the message box says "This graph cannot preview". And when i open 'YouCam' the message box says "YouCam cannot connect to your webcam(USB Video Device) try selecting another capture device within the setting." But in the setting, there is no other capture device only the USB video device... Please help me. I CANT SEEM TO FIND THE RIGHT SOLUTION
Try using a real HP driver yet?
downloaded from whom, most non HP sites are virus pits from H3LL.
know that first.
finding drivers for obsolete systems is super hard work.
Pavilion dv6000 (is that the full partnumber or the useless series number)? post the service tag for 10x better answers.
if at HP.com (where you should have gone first) they demand that first. that is because, there are 50 LT in that series.or more
and guess what they all dont use the same chips nor cameras.
carbon date,,,, 2006 ,2007?
just about 10 years old and support ends at 10 years old
XP is dead now for 3 years why run XP
XP must have SP3 loaded, service pack 3 or USB is no good and vast other things super bad.. (old old history that)
only this matters, see those xx below, all facts here matter.
1,2,3 , all do. to match drivers; to OS. just 1 example here of 1000
here is the dead files on this LT
deep dead.
http://h30434.www3.hp.com/t5/Printers-Archive-Read-Only/Windows-7-Upgrade-Guide-for-dv6000-dv9000-models/td-p/179816
if you read the real service manual on any HP laptop made
you learn fast there are vast variances in chips used.
and matching drivers same,
some have 3 -4 wifi chips different. in one model.
like this DV6000-1234, see that 1234, vast models exist.
world wide in fact.
SOURCE: no connection
try to all usb ports on cpu .reinstall your cam drivers to after removing old drivers.
SOURCE: driver ricoh webcam HP pavilion DV6000
I had the same problem of code 10. I am using an HP pavilion dv6000 with a ricoh webcam. I found that I download a microsoft updates on the 8th of febuary which included some sonix drivers which were optional and no good to me but stoped my webcam working.
By going into 'control panal' and selecting 'system' then 'devise manager' you get a list of your system. If you then select the 'universal serial bus controlers' at the bottom you will see the sonix driver. By rolling back this installed driver I found my webcam started working again.
This solved my problem and I cant believe there aren't a lot of people out there with the same problem. Good old microsoft!
SOURCE: driver of HP pavilion dv6000
You can download the required installation drivers and software from manufacturer's site by clicking this link
On the page which opens, select the operating system of your computer to download the appropriate drivers and software.
Hope this solves your problem. Thanks
