I bought a used Kenmore Elite top loading washing machine. I hooked up it fine, checked for leaks, and found no leaks. I ran the machine to clean it out and it ran fine, until the rinse cycle The machine started to leak when the self-leveling feature activated. The water is coming from the bottom right of the machine (as you're looking at the machine. I can't tell where the water is coming from.
My Washing machine is leaking in gearbox.the quality of water is bad (Hard)
I WAS NOT LOGGED ON WHEN I LEFT THE NEWEST REPLR PLEASE LEAVE A MESSAGE AND I WILL GET A AUTO UPDATE ON YOUR QUESTION ... Joe_Rex
ON NEWER MODELS THE WATER SUPPLY AND DRAIN ARE THE SAME CONNECTION THAT "SNAPS or TWISTS" ON TO YOU KITCHEN OR LANDRY ROMM FAUCET. ########### IF YOUR DIDH-WASHER ######### IS A BUILT-IN WITH NO FAUCET SUPPLY THE NEXT SUGESTIONS DO NOT APPLY ARE THE SUPPLY AND DRAIN BOTH. THE DRAIN LINE IN THAT CASE IS ON THE BOTTOM OF THE HOSE COMBO. WATEVER DRAIN OUTLET OR INLET YOU FIND ... GETS SOME RAGS A BUCKETS READY AND GET A GARDEN HOUSE ... IF YOUR WASYER IS ON ROLLERS ... MOVE IT TO THE KITCHEN DOOR. LOOK CAREFULLY INSIDE TO SEE IF TRAYS REMOVE EASY FOR YOU.... IF SO LIFT UP THE SPRAYBARE UNIT AND SET IT SAFELY ASIDE ... DONT LET IT GET BENT.YOU SOULD SEE A DRAIN HOLE DOWN IN THE BOTTOM OF THE INSIDE NOW ... MAY NEED A FLASH LIGHT. PLACE THE FAUCET ASSEMBLY AND ANY OTHER HOSE YOU SEE IN THE BUCKET SECURELY. WITH YOUR HOSE NOZZLE END , SLOWLY TURN OR SQEEZE THE SPRAYER TO GET A STEADY FLOW. NOTICE WHICH HOSE STARTS DRAINING WATER INTHE BUCKET. NOW YOU HAVE FOUND THE LINE AND CAN FLUSH IT OUT REAL GOOD WITH THE HOSE WATER PRESSURE JUST A FEW SHOTS. THYAT IS THE FIRST NO-COST NO-PLAYING WITH ELECTRICITY SOLUTIONS.
MAKE SURE TO FLUSH-OUT DRAIN LINE. WATER IF IT IS DRAINING TO SLOW WILL START LEAKING AROUND THE LOWER PART OF THE WASHER WHERE THERE IS A SAFTEY OVER FLOW ... IF YOURS IS A FREE STANDING TOP LOADER THE DRAIN HOSE IS IETHER SEPERATE OR FLOWS WITH A CHECK VALVE THAT HOOHS RIGHT TO YOUR FAUCET. MAKE SURE THE CHECK VALVE AT THE FAUCET CONNECTION IS FREE AND NOT STUCK.
Joe,
How do I flush out the drain line? A hose in the machine tub?
It sounds like these suggestions are for a dishwasher and not for a washing machine. Am I reading this incorrectly?
My Maytag washing machine has the same problem only difference is it leaks from the top left seam when the cycle gets to spin.
I have a Maytag washer about 5 years old and now leaks from the bottom during the rinse cycle. Just started a day before hearing squeaking for the past week while it was washing and rinse cycle.
this is not a stackable unit, It is the older combo, the washer leaks from the botom when the machine enters the rinse cycle. when it starts draining the water comes out the bottom of the machine.
