Frigidaire Affinity ATF7000E Front Load Washer Logo
paul langry Posted on Oct 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Diagram to show pump filter on an affinity - Frigidaire Affinity ATF7000E Front Load Washer
  • Official Brand Answer 4,342 Answers
  • Posted on Oct 22, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467608
Points
5907
Hello - After further researching it does not seem that there is an actual diagram available. However you may try the following steps to clean out the coin trap on an Affinity washer. Please be very cautious and it is actually recommended for this to be done by an actual certified technician.
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
I have an Affinity washing machine that shows an E23 error code.
Hello Robert Reische, thank you for your inquiry!
I understand that your Frigidaire washer is showing an "E23" error code. Based off the information I show "E23" stands for drain pump relay on board failed or wire off the pump. Which means you could have an issue within the main control board or wiring to pump. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance. Hopefully this helps. -Matt
Affinity washer flashing EFO
Good Morning Friend,
I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Put the filter back on, affinity
Which filter are you speaking of? The coin filter trap in the pump area?
2helpful
My frigidaire affinity washer doesnt spin during the rinse cycle.
Hi javierc569,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Frigidaie affinity washer not puping water. I pulled the pup outy, it seems to be freely spinning. The filter looks like a pipe with an end cap. Does that come out and does it act as a filter. I did find...
the screws and nails were your problem put it back together if it still doesnt pump the pump motor has overloaded from the propeller being obstructed and needs to be replaced.
My Frigidaire Affinity ATF6000FS1 front loader will drain and function properly until it gets to the final spin. it shuts off when there is about 7 minutes left on the timer. I have tried small loads...
It's the timer control, not the motor or filter. Try a different setting. You should also be able to find more information on the manufacturers website, along with a manual and possibly a diagram. Also You Tube is a good place to find out more on how to repair it.
How to clean a affinity frigidaire front load washer drain pump filter?
remove the toe kick panel just below the front door and its located right below the drum
Affinity ATF7000E Front Load Washer: where do i find what efo means on my affinity wash...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
