I have a (Costco) Elite Platinum II Spa with a Balboa VL700s topside control P/N 53896. I've had the SPA off for a year (drained) and am now poweing it back up. I get 8888 showing on my topside control when I power up, None of the buttons work, but I have power to the control. The pump is running but I can't turn any of the jets or blower on. Do I need a new Circuit Board, Topside COntrol, or is something else wrong. After about 5 minutes I get a 83 degree reading and it just stays there but no functionality....
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
SOURCE: When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
SOURCE: hi have problem with canadian spa
OHS, OH, or SPA TEMP LMT Message
There is an "Over Heated Spa" (OHS or OH) Water Condition.
One
of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water
Temp and Spa Functions are Disabled. System will Auto Reset when Water
Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High
Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
In order for the Spa Water Overheat Error Message to Automatically
Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP
LMT" Spa Water Overheat Error Message has Cleared. If the Error Message
has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
I'm in the U.S. Sorry.....
did you ever find out what this issue was
