Dryers Logo
Harvey Henry Iv Posted on Oct 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F25 error code
Placed front thermal fuse and the thermal cut-off. dryer worked for three loads of laundry and died again. When checking these two pieces this morning they are blown out again. I noticed dryer was getting a little hot than normal which I thought was because I cleaned out the huge lint build up. Is the high limit thermostat causing this issue because the dryer was so hot. Is this unit not cutting off the temp. which is blowing my fuses?
Richard Roth
Level 3:
Top Expert:
  • Kenmore Master 9,472 Answers
  • Posted on Oct 17, 2012
Richard Roth
Kenmore Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626516
Points
28464
Having an error code on your appliance can be an inconvenience and I know how important it is to have a good working dryer.
The "F25" indicates the INLET THERMISTOR is shorted or the INLET THERMISTOR circuit is shorted. If you replaced the inlet thermistor and control board then it may have bad inlet thermistor circuit. You should disconnect the thermistor circuit connections at the thermistor and control board and test the thermistor circuit for continuity. Check the circuit to see it happens to be open or shorted with an ohm meter.
The inlet thermistor is located on the side of the heating element housing is a thermistor and high limit combination. The part number is 8557403. The inlet thermistor portion of the thermistor/high limit will have two solid red wires connected to it. It could have faulty new thermistor or it could have an open or shorted thermistor circuit or a faulty control board. The thermistor can be checked with and ohm meter. Disconnect the two red wires and place the ohm meter leads across the two terminals. At room temperature it should measure approximately 50k ohms of resistance. If it measures 50 k, then it should be reconnected and then the sensor circuit disconnected from the control board and retested at the harness wires to see if you get the same measurement reading. If it does measure the same, and it continues to display F25, it could have a faulty control board.
What is your model number?
5 Related Answers
Anonymous
  • 291 Answers
  • Posted on Sep 15, 2007
SOURCE: Roper household dryer not heating
you can unhook themal cut out or themostates hook the two wires together tape or make sure they dont touch anything and test dryer.. if heat comes on thats the problem
A
Anonymous
  • Posted on Dec 18, 2007
SOURCE: My dryer won'y blow hot air
Bob, I did not lie, I just checked the heating element orginally with an Olm meter while the element was still installed in the dryer. After more reading on the internet and testing I decide to remove the heating element and noticed it had the short.
Anonymous
  • 750 Answers
  • Posted on Sep 22, 2008
SOURCE: no heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Anonymous
  • Posted on Apr 07, 2010
SOURCE: Thermal cut-off blows and high limit thermostat is
in this case we put the lower temp thermostat in the oven at 170 degrees till it was hot and measured with ohm meter and it was open. After it cooled down some it went back to being a short. Now with this part in the dryer and the new high temp thermostat
and it blew shortly after being turned on. A possiblity is that there is a short by passing the 150 degree thermostat and the element keeps being on and causes the 350 degree thermostate to blow.
Sal De
  • 2699 Answers
  • Posted on Apr 19, 2010
SOURCE: 41799980100 Kenmore Laundry Center dryer themal fuse blows
you need to clean out the dryer.the thermal fuse is a safety switch so you don't have a fire when the dryer is running to hot.blow out the vent line with a leaf blower,unplug the dryer and make sure the outside vent is clear.next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,do this once a year,your clothes will dry on time,no fires and you'll save on parts.let me know how you make out
2answers
I have the whirlpool cabrio wed6200sw1 dryer and when i set the drying time to 45 minutes drying time,the timer count's down in about 20 minutes and ends the cycle, got a F25 code when I ran diag's
f25 is a bad thermisiter,find the tech sheet in the dryer and it will tell you how to read out the thermisiter,if the thermisiter is good then you have a bad computer board.
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 • LG Dryers
4helpful
2answers
I have a Whirlpool Duet Dryer model WED9400SU0. The thermal fuse went out last week. I replaced the fuse and fully cleaned the vent and internals of the dryer as well as the full path to the outside of...
to the touch the clothing should not be very hot, i see where ya have cleaned the vents(good job!!)
on occasion i have found where a fabric softner sheet has clung to the face of the lint filter housing,look at the plastic housing around the area of where the lint filter goes and see if something is stuck to it restricting the air flow into the filter housing
I got a f25 code on my he5 Kenmore washer . What is wrong?
This is a communication error with the motor. The first spot I would check the MCU on the lower front of the unit. Remove the lower front panel three screws check the wires there unplug and plug back in if that does not work check the wires on the top board. The top has three screws in it then it will slide back and off.
Apr 26, 2010 • Kenmore HE5
4helpful
Kenmore elite, model 110 60952990,stopped working after I tried to dry a pair of sneekers. It doesn't do anything when the power butten is pushed. Thank you.
The thermal fuse (part number 3390719) is blown causing the motor not to run. This thermal fuse is located on the blower housing beside the thermistor (part number 8577274) and it is wired in series with the motor thereby cutting power to the motor when it fails. The failure of the thermal fuse is due the failed thermistor; these requires both the thermal fuse and the thermistor to be replace.
Access to the thermal fuse and the thermistor for replacement or testing requires the removal of the lower front access panel which is secured to the front panel by two retaining clips positioned about three inches away from the sides. Pry the clips to release it and remove the lower front access panel. The thermal fuse and the thermistor can now be accessed.
Using a volt-ohmmeter, check the continuity of the thermal fuse which is to the left of the thermistor. Replace the thermal fuse if it reads open together with the thermistor.
Remove the mounting screws and mount the new parts in place. Disconnect the wires from the old failed parts and connect it to the corresponding component. Reinstall the lower front access panel back into position.
I replaced the thermal fuse and it blew again shortly after.
The main cause for thermal fuses to blow is a restricted airway. You need to make sure that your path for airflow is clear:
Check your dryer hose: make sure it is clear of debris inside, make sure it is not kinked when the dryer is in place.
Check your dryer vent: some houses and apartments have a fairly long dryer venting system before it reaches outside.
Check your dryer: just after the lint trap and prior to the blower motor is a common place for a blockage. You may have to take the front of the dryer apart to get to it. I have seen all kinds of things get passed the lint filter.
Each of these things would cause even a new thermal fuse to blow quickly. A combination of them could easily do that. The thermal fuse is the dryer's safety cut off, preventing your dwelling from burning down from an out of control dryer. So it's all about airflow, airflow, airflow.
2helpful
2answers
Fault code F25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
I got this working for many on this site :)
Thanks
Fame !
1helpful
2answers
Kenmore HE2 Dryer makes three beeps but wont start
Check your door closer switch. Mine was doing the same and it turned out to be as easy as changing the switch.
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
