SAMSUNG SpinPoint M7 Device Model: SAMSUNG HM500JI Serial Number: S1WFJ9FB211011 LU WWN Device Id: 5 0024e9 2048729cc Firmware Version: 2AC101C4 User Capacity: 500,107,862,016 bytes [500 GB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: 8 ATA Standard is: ATA-8-ACS revision 6 Local Time is: Tue Oct 16 11:08:23 2012 UTC SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: FAILED! Drive failure expected in less than 24 hours. SAVE ALL DATA. See vendor-specific Attribute list for failed Attributes. General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 137) The previous self-test completed having a test element that failed and the device is suspected of having handling damage. Total time to complete Offline data collection: ( 8040) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 134) minutes. SCT capabilities: (0x003f) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 001 001 051 Pre-fail Always FAILING_NOW 78158 2 Throughput_Performance 0x0026 252 252 000 Old_age Always - 0 3 Spin_Up_Time 0x0023 092 090 025 Pre-fail Always - 2650 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 711 5 Reallocated_Sector_Ct 0x0033 252 252 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 252 252 051 Old_age Always - 0 8 Seek_Time_Performance 0x0024 252 252 015 Old_age Offline - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 1237 10 Spin_Retry_Count 0x0032 252 252 051 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 099 099 000 Old_age Always - 1089 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 691 191 G-Sense_Error_Rate 0x0022 100 100 000 Old_age Always - 7774 192 Power-Off_Retract_Count 0x0022 252 252 000 Old_age Always - 0 194 Temperature_Celsius 0x0002 064 055 000 Old_age Always - 34 (Min/Max 20/49) 195 Hardware_ECC_Recovered 0x003a 100 100 000 Old_age Always - 0 196 Reallocated_Event_Count 0x0032 252 252 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 089 074 000 Old_age Always - 343 198 Offline_Uncorrectable 0x0030 252 252 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0036 100 100 000 Old_age Always - 11 200 Multi_Zone_Error_Rate 0x002a 001 001 000 Old_age Always - 69474 223 Load_Retry_Count 0x0032 099 099 000 Old_age Always - 1089 225 Load_Cycle_Count 0x0032 098 098 000 Old_age Always - 29721 SMART Error Log Version: 1 ATA Error Count: 12103 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 12103 occurred at disk power-on lifetime: 1232 hours (51 days + 8 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 80 c6 62 cd e0 Error: UNC 128 sectors at LBA = 0x00cd62c6 = 13460166 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 00 80 c6 62 cd e0 00 00:00:59.338 READ DMA c8 00 80 c6 62 cd e0 00 00:00:59.336 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.334 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.331 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.329 READ DMA Error 12102 occurred at disk power-on lifetime: 1232 hours (51 days + 8 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 80 c6 62 cd e0 Error: UNC 128 sectors at LBA = 0x00cd62c6 = 13460166 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 00 80 c6 62 cd e0 00 00:00:59.336 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.334 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.331 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.329 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.327 READ DMA Error 12101 occurred at disk power-on lifetime: 1232 hours (51 days + 8 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 80 46 62 cd e0 Error: UNC 128 sectors at LBA = 0x00cd6246 = 13460038 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 00 80 46 62 cd e0 00 00:00:59.334 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.331 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.329 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.327 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.325 READ DMA Error 12100 occurred at disk power-on lifetime: 1232 hours (51 days + 8 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 80 46 62 cd e0 Error: UNC 128 sectors at LBA = 0x00cd6246 = 13460038 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 00 80 46 62 cd e0 00 00:00:59.331 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.329 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.327 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.325 READ DMA c8 00 80 c6 61 cd e0 00 00:00:59.323 READ DMA Error 12099 occurred at disk power-on lifetime: 1232 hours (51 days + 8 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 80 46 62 cd e0 Error: UNC 128 sectors at LBA = 0x00cd6246 = 13460038 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- c8 00 80 46 62 cd e0 00 00:00:59.329 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.327 READ DMA c8 00 80 46 62 cd e0 00 00:00:59.325 READ DMA c8 00 80 c6 61 cd e0 00 00:00:59.323 READ DMA c8 00 80 c6 61 cd e0 00 00:00:59.321 READ DMA SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed: handling damage?? 90% 1237 0 Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run SMART Selective self-test log data structure revision number 0 Note: revision number not 1 implies that no selective self-test has ever been run SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Completed_handling_damage?? [90% left] (0-65535) 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
SOURCE: Hard disk data recovery from a bad sector
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
SOURCE: remove the bad sector from samsung sp0411n
Although A format could help it sounds more like you have some bad sectors on the harddrive.
Right click on the drive, select properties, then select the tools menu and initiate a disk check. it will give you an option screen before it proceeds, select the option to scan for a recover bad sectors/clusters. This will write off and mark the bad sectors so they will not be used again. If the problem comes back again soon then your palette media is failing and you should replace the drive.
Good luck and let us know how you make out,
Chris
