I only need two programmes so can I get rid of the 3rd one
SOURCE: honeywell st7000
what type of system do you have? cool/gas heat, heat pump, electric cool & heat. split system or package unit?
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
SOURCE: unlock Honeywell TB7220U1004 Ultrastat Commercial
Pull off face and remove batteries and reinsert.
SOURCE: how do i remove my st699 honeywell programmer from
Because there are no apparent screws to remove the front of this unit it can be very confusing if you have not done it before. Underneath and to the right hand side you will find a small notch in the plastic, it can be difficult to see when the unit is on the wall, using a small terminal screwdriver push upwards on the plastic tab which locks the front in place and with a slightly larger flat bladed screwdriver prise the front off bottom first then the two locking tabs at the top.
You will probably find that the back case is fastened to the wall with two screws.
Replacement is simply a matter of snapping the front back into the case.
SOURCE: how to unlock a trane pzs programmable thermostat
Unlock???? You mean reprogram???....should be a button says Program or set program etc....Mode.....or remove the batteries for 10 minutes and start over
