SOURCE: Toshiba studio 281C problems
You should be able to print on both, but I wouldn't advise it at all. The envelopes are going to jam a LOT and you WILL eventualy get a label stuck inside the machine. Possible....yes. But I don't recommend it. :)
C
SOURCE: wrong count
You find that answer out on copytechnet.com. There are authorized Toshiba reps available on there to answer your question.
I don't work on Toshiba unfortunately. If I did I would give you the answer.
SOURCE: wrong count
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
SOURCE: Toshiba e-studio 3511 has printing issued on one
These copiers have serious toner dust issues. Light copies are usually caused by dust in the optics (the mirrors) and on the laser glass.
Take off the main copy glass and gently clean all the mirrors and scan bulb underneath it - be careful.
If you remove the drum unit and look inside the cavity you took it out of you will probably find a huge toner mess. the laser glass is situated in this cavity and needs to be cleaned - just clean whatever you can see...
SOURCE: network initializing message for Toshiba
This is normal each do you turn on the copier for 1 until 5 minutes, next to this time do you have firmware problem.
Do you have a nice day
